FredForssell wrote on Mon, 06 December 2004 12:33 |
Millennia Media have a discreet modular system called "Mixing Suite"
The Millennia Media mixing suite uses a 99.99% IC opamp signal path. It is not a discrete design.
Wasn't aware of this, sure it sounds quite reasonable anyway.
The Millenia unit is compatible with GML mod 9100, but must have different signal path topology..
Recently I've been exploring the possibility of a specialized portable unit for doing front of house sound at concerts.
Something with minimal functionality and maximum integrity:
Twelve to sixteen channels, two to four aux sends and variable highpass. Ideally the unit is rackmountable and road worthy, while delivering a premium analog path.
The plan is to patch the single bus output through a good graphic and then into the mains, bypassing the Soundcraft, Yamaha or Midas that is usually present.
In addition to vastly improved sound, the hope is to minimize some of the hassle taken to bypass the strip eq's, gate and comp inserts, bus groupings and vca assignments that are standard fare, and almost invariably hooked up by the techs in advance...
Any suggestions on where to go with this? (the 9100 might be the perfect item if the channels could be fitted with variable highpass filters.)
Cheers,
Eric
