voidar wrote on Tue, 26 October 2004 20:43 |
But would you use it for recording (drums or live especially)? Probalby not if you have better alternatives. To put it this way, what do the pres lack in character? Pros/cons. I think there is a general agreement on that A&H gear sounds better than Mackie gear. My question would thus be why? What characteristics does A&H gear have which put them above Mackie?
I've been using the pre's in my Saber for a lot of recording; drums, guitars and so on. They've got a lot of juice and power, outperforming several outboard preamps around mid-price and above. Hit a snare with an SM57 at minimum gain and it goes through the roof, I sometimes have to pad that pre. I mean, most other cheap desks I've used will require you to crank the gain to even get the SM57'ed snare popping.
The pre's will saturate and distort in a pleasant manner, I've been using it to dial in overdrive that can sometimes sound much better than pedals etc
The EQ is very responsive, and you can usually boost a lot more while maintaining a musical sound compared to Mackie etc. However, whenever I listen and EQ without watching it turns out that very little EQ boost is needed to have things happen to the sound. That's where a good EQ starts, in my book.
With a lot of cheaper EQ you hear things go "swoosch" when tweaking the sweeps, but with some better stuff you don't hear that. Instead, you hear the EQ actually massaging what's already there in the sound. If it ain't there, you can't boost it, and if it ain't noise it won't swoosch. The Allen & Heath EQ in the older consoles are like this. Mackie and especially Behringer go swoosch on me.
Someone wrote that the newer versions didn't sound as good as the old ones and I have to agree. Although the recent ones don't sound bad at all, still I feel they lack some of the depth and rich character you can get with the earlier models.
Only too bad it can be a bit noisy sometimes, but nothing that would prevent you from making beautiful music.
Cheers,
Tomas Danko
www.danko.se
