R/E/P > R/E/P Saloon
Unwanted vibrations
(1/1)
AlexBrod1:
Hello, friends! I have a problem with my plane. During the last flight, I noticed that vibrations arose, especially at high speeds. I suspect that this is due to the imbalance of the propeller. I understand that this can be fixed even in the field, but I just don’t know how exactly. Has anyone encountered this? Tell me where I can find reliable materials on this topic?
Mark1654:
Hello! Yes, I encountered a similar problem. I searched for a long time for a solution until I found an article that turned out to be very useful. It describes in detail all the steps for balancing a propeller in the field. It also mentions typical mistakes that can be made, and gives recommendations on choosing tools. I especially liked that the material is structured and understandable even for those who are doing this for the first time. I advise you to read this Propeller imbalance, it really helped me figure out and solve the problem.
AlexBrod1:
Thank you, it's great that an active community will always help in any situation, tell me if there are any more nuances
Mark1654:
Propeller balancing is an important stage in aircraft maintenance, especially if vibrations occur during flight. The procedure can be performed even in the field, but it is important to approach it with due attention and use the right tools. This will not only reduce vibrations, but also increase the overall safety and comfort of flights. By adhering to proven methods, you can significantly extend the service life of the equipment and avoid more serious problems in the future.
Navigation
[0] Message Index
Go to full version
