Author Topic: How to Open the M49v to Access S4 Switch  (Read 1051 times)
Mannix
  • Real Full Name: Ernie Mannix
« on: July 27, 2024, 11:29:11 PM »
On an M49v, how do you take off the head basket and body to access the S4 switch? Does it unscrew?
I don't have the mic in hand as yet, but when it arrives I want to compare the settings.
Any other caveats or tips? Thanks, in advance.
Ernie
klaus
Re: Opening the M49v to access S4 switch
« Reply #1 on: July 28, 2024, 12:55:38 PM »
With a 2-2.5mm blade screwdriver, gently screw IN three housing screws until you feel a stop
Remove the housing which includes the head basket by rotating it back and forth as you lift it up
Two red miniature switches on the green side board of the mic amp will now be visible, one positioned vertically, the other horizontally
Move the left, vertical, switch UP, to make the amp response linear, removing the low end cut
Reassemble in reverse
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
Mannix
Re: How to Open the M49v to Access S4 Switch
« Reply #2 on: July 28, 2024, 04:07:21 PM »
Thanks much.
-Ernie
Mannix
« Reply #3 on: July 30, 2024, 03:47:38 PM »
One more question: I know the U67RI can use the vintage U67 cables, and that the new cable for both the U67RI and the M49v are similar... so, could I use a vintage U67 cable on a new M49v? -Thanks in advance.
- Ernie
klaus
« Reply #4 on: July 30, 2024, 08:32:05 PM »
No, you could not.
For one, the pinouts are different; for another, the key that lines up the connector with its mate is offset on the U67, so it would not even work mechanically.
Klaus Heyne
German Masterworks®
Mannix
« Reply #5 on: July 31, 2024, 01:17:49 PM »
Will an M269 cable (ends pictured) work on an M49v?
The reason I am looking is I have the U67RI and the cable drives me nuts. Tangle monster. Sounds fine, but if possible for the 49v, I'd like something more robust. Any other suggestions would be appreciated.
klaus
« Reply #6 on: August 01, 2024, 10:09:09 AM »
Yes, any cable for any M2xx mic, including the M269 cable you show, will work, be correctly terminated and produce the right voltages.
Klaus Heyne
German Masterworks®
Mannix
« Reply #7 on: August 03, 2024, 03:34:05 PM »
Appreciate the help. Thanks. I bought that cable. NOS. Still has a Neumann hang tag.
Cheers.
-Ernie
Page created in 0.015 seconds with 18 queries.
