PaulyD wrote on Thu, 30 September 2004 07:28 |
I realize there can be zealots from both camps (i.e. analog vs digital summing), but it truly puzzles me how even top professionals can suddenly develop this bent for sterilizing the audio chain at mixdown time.
I don't think anyone is really advocating digital summing as "better" than analog summing - just cleaner. I think most recognize the subjective benefit of the added harmonic distortion and noise when it suits the desired purpose.
Having said this, I will also say that anything done in analog summing CAN be done in digital summing if the designers of the equipment aimed for these results. To date that has not been their aim, much to my chagrin and conversations I've had with them on the matter. If such a situation were to occur that a digital device were given the same mathematical algorithm that is achieved in an analog environment then I believe it would be difficult to make the case to spend the money on the analog gear. Anything that can be done in analog can have a mathematical formula associated with it and therefore can be duplicated in digital.
Finally, just for clarification, on the work that I have done I do prefer the digital mix for various reasons, but I have generally worked on material wherein the desired goal was more of a scientific documentation of what was there rather than an artistic improvement upon it. Working with classical singers (opera) my goal has been to preserve exactly what came out of their mouth from microphone to CD, so total transparency has always been my aim. Therefore, I have used the digital summing available to me.
Quote: |
I mean, some of the comments here strike me as subtle jabs at those who prefer analog summing.
I think this is because the terms "distortion" and "noise" are interpreted as pejorative.
Quote: |
Is it not true that when a fader is pulled down in a DAW, bit resolution goes down with it?
This is indeed not true on any of today's digital mixers on the market, from Protools HD to the Sony Oxford to a Yamaha DM2000 to Cakewalk to some cheap Samson box if there is one. The analog only guys tend to take the approach that digital is inherently broken and analog is only broken in a subjectively pleasing way, so analog is preferred. This is not so. Digital systems are not inherently broken despite conventional wisdom, market hype, and entry level college courses.
Quote: |
So, if one pushes all signals out of their DAW / D/A as hot as possible without clipping, then sets levels with faders in an analog mixer, they're getting maximum bit resolution at the tradeoff of added noise and distortion? But what if most listeners do indeed find that noise and distortion pleasing? Wouldn't that be a win-win situation?
They would be getting maximum bit resolution if they mixed within the DAW environment also. So all that is left for the difference is the addition of the extra noise and distortion - which you either like and therefore use the analog equipment, or you don't like so you use the DAW.
Good post, Paul.
Nika.
