Author Topic: U67 Connector: Correct Terminations  (Read 1356 times)
Derek Samuel Reese
« on: December 09, 2023, 08:24:32 AM »
I am looking for a detailed wiring diagram for a female u67 connector.
I have a blue binder female connector in my swivel mount and I want to put a proper tuchel female connector.
I’m not sure if wires are numbered or what color they might be ?
I’m looking for something very straightforward so I can wire a new female connector properly.
Also if this can include the grounding wires please.
The space to solder these wires is very small,
I am going to attempt this on my own once I know where each wire goes :-)
Also I wanted to make sure that I can use this female connector portion inside my swivel mount ? This picture is of the female connector but for the power supply.
And yes I realize I have to rekey this connector.
klaus
Re: U67 female cable wiring
« Reply #1 on: December 09, 2023, 01:22:36 PM »
Pins are numbered on Tuchel and Binder connectors which are interchangeable, i.e. each will fit where the other was previously installed.
Pin #1: Audio (+)
Pin #2: Audio (-)
Pin #3+#7: Ground and Shield
Pin #4 Heater
Pin #5 B+
Pin #6 nothing
Make sure to connect a wire between cable ground/shield and connector housing. The best place: clamp the wire under the strain relief bridge held in place with two screws at the rear end of the connector housing.
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
Derek Samuel Reese
Re: U67 Connector: Correct Terminations
« Reply #2 on: December 10, 2023, 07:33:32 AM »
Thank you Klaus for responding.
sorry for the novice questions...
Just so I am clear,
you said Make sure to connect a wire between cable ground/shield and connector housing
By wire you mean Pin #3+#7: Ground and Shield ?
klaus
« Reply #3 on: December 10, 2023, 12:44:52 PM »
Connect ground and shield as mentioned, THEN solder a wire between the ground lug and either pins 3 or 7 (they are now already connected, if you follow the instructions).
Klaus Heyne
German Masterworks®
Derek Samuel Reese
« Reply #4 on: December 10, 2023, 07:46:59 PM »
I don’t know what a ground lug is ?
I apologize.
Will any kind of wire do ?
also in the picture i uploaded, it looks as though there are more than one wire connected to the strain relief or cable housing ? The copper and black wire
klaus
« Reply #5 on: December 10, 2023, 09:39:14 PM »
The ground lug on connectors is a metal bridge used as strain relief) or a metal loop/tab that electrically grounds the housing of the connector.
In my picture (by the way it's copyrighted and you should acknowledge copyrighted images!) the ground lug is the metal loop where the two black ground wires and the cable shield are soldered to. Any kind of wire will do.
On the connector pictured there are two ground wires, because separate wires were soldered to pins #3 and #7, rather than making a jumper between the pins, with only one lead out to ground the connector housing. The green wire is the actual ground wire in the cable.
Klaus Heyne
German Masterworks®
Page created in 0.031 seconds with 20 queries.
