Author Topic: Recommended Maximum NKMu Heater Voltage Output  (Read 179 times)
Ron Sweet
« on: January 30, 2023, 02:34:26 PM »
How much of a heater voltage drop would you expect along a KM56 mic cable, compared to the heater voltage output of an NKMu power supply? What's a good maximum heater voltage as measured on the power supply output? If there's a reasonable answer, then I can avoid disassembling my KM56 to measure the heater voltage there. The NKMu schematic shows a heater voltage output of between 4 and 4.4 volts. Thanks for any insight.
Ron Sweet
klaus
Re: Recommended Maximum NKMu Heater Voltage Output
« Reply #1 on: January 30, 2023, 03:01:20 PM »
From experience: an original 10m Dörfler tube mic cable as was used by the broadcasters back then, would have a heater voltage drop of about 0.05-0.07VDC.
So if you set up your supply to put out exactly 4.00 VDC, you will be in the sweet spot for AC701 longevity and noise floor: 3.92-3.96VDC.
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
Page created in 0.034 seconds with 20 queries.
