March 26, 2023, 11:40:33 PM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
R/E/P
Klaus Heyne's Mic Lab
(Moderator:
klaus
Schoeps CMTS 501U Repair
« previous
next »
Pages: [
1
2
All
Go Down
Print
Author
Topic: Schoeps CMTS 501U Repair (Read 982 times)
Barry Hufker
Newbie
Online
on:
December 15, 2022, 11:16:43 AM »
I'm posting in the hope I can get some information about finishing the repair of this microphone. It was damaged in a great fall onto a marble church floor. After considerable time and expense, the mic has been straightened, but in my distress, along the way I didn't pay attention to how these parts (marked in the photos) fit. I would be grateful if someone, and especially Klaus or David Satz, can provide an answer. I'm willing to pay for this information if needed. So: specifically I need to know where and how these parts (marked A and B in the photo) fit. Thank you. It is a very fine mic and I'd like to see it restored not only for my use but for a future generation.
Barry Hufker
Newbie
Online
Re: Schoeps CMTS 501U Repair
Reply #1 on:
December 15, 2022, 11:22:31 AM »
Here is how the mic looked after the fall.
Barry Hufker
Newbie
Online
Reply #2 on:
December 15, 2022, 11:23:26 AM »
Here is how it looks now...
Kai
Sr. Member
Offline
Reply #3 on:
December 17, 2022, 11:30:52 AM »
Quote from: Barry Hufker on December 15, 2022, 11:16:43 AM
... I need to know where and how these parts (marked A and B in the photo) fit.
From looking at the picture, try the following:
There are two possible orders of parts, depending how far the golden contact square sticks out inside the capsule housing:
(V1: Insert one full circled springs)
Dry-wipe, then insert the golden ring into the capsule housing.
It’s contact tongue should be centered between the two contact pins, pointing outside to the mic body, serials visible.
It’s backside must make direct contact with the little golden square visible.
On top should go (V1, one) or (V2, two) full circled springs.
V1 is very likely if the golden ring in this case still makes contact with the golden square in the capsule housing.
It’s tongue makes contact with the other golden square, in the mic body.
The open circled spring should lock everything then, by snapping into a circular groove (photo not detailed enough to see).
The pin of the open ring-spring should align with the little hole in the mic body.
Barry Hufker
Newbie
Online
Reply #4 on:
December 17, 2022, 02:16:27 PM »
Thanks for responding. I now know from another source the tongue on the brass part makes contact with the brass rectangle at the bottom of the capsule. I'll investigate your suggestions. Thank you for helping!
Kai
Sr. Member
Offline
Reply #5 on:
December 17, 2022, 04:18:54 PM »
Interesting, then the rectangle on the body might only be a shield.
Are there a threads on the golden ring and the capsule housing?
Barry Hufker
Newbie
Online
Reply #6 on:
December 17, 2022, 07:29:05 PM »
The following information comes from Reso Labs (Russia) through the efforts of George Toledo, who contacted them on my behalf. Many thanks to them both!
Kai
Sr. Member
Offline
Reply #7 on:
December 18, 2022, 06:37:10 AM »
This coincides with what I thought.
The clear evidence for the gold ring orientation is the serial numbers written on it:
All my Schoeps capsules have them, and they are
visible.
It’s only the question if one of the circled springs can go underneath while the golden square on the capsule side can still make direct contact to the golden ring.
Are you sure the 2nd circled spring shouldn’t go elsewhere, isn’t missing somewhere internally?
Just try, check if the mic works and nothing is rattling.
Else contact the friendly people at
www.schoeps.de
Friendly and helpful with obsolete models? Not my experience KH
Barry Hufker
Newbie
Online
Reply #8 on:
December 18, 2022, 11:36:45 AM »
Kai,
Thanks for your continued thoughts and help with this! It is greatly appreciated.
The project unfortunately will have to remain untouched for the next few days due to other commitments...
I initially tried the folks at Redding Audio, who were as helpful as they could be. I approached Schoeps directly and there has been no response. As you probably know they don't service this model any longer and I guess that means they don't answer questions either...
Best regards!
David Satz
Full Member
Offline
Reply #9 on:
December 19, 2022, 04:41:31 AM »
Barry, I happen to be at Schoeps right now, so I asked who got your email. It was received on December 3rd, and Bernhard Vollmer replied on December 5th with instructions for reassembling the microphone. Did you not receive it?
--best regards
btw, Bernhard is officially mostly retired at this point.
Barry Hufker
Newbie
Online
Reply #10 on:
December 19, 2022, 01:23:24 PM »
Hi David,
Thank you for posting. No, I did not receive Mr. Vollmer's reply. I am so sorry. I had high hopes he would and it's great to know my faith was not misplaced. I have not found it in spam either. I am sending you my email address by Private Message.
Barry
Barry Hufker
Newbie
Online
Reply #11 on:
December 19, 2022, 05:14:38 PM »
As it turns out, on December 5, Mr. Bernhard Vollmer of Schoeps wrote me a reply to my message to him, but somehow his message never made it to me, until today with the kindness and assistance of David Satz. Now I have Mr. Vollmer's instructions as to how to put the mic together.
My great thanks to George Toledo, the folks at Reso Labs, Kai (from this forum), Klaus (for providing this forum), Bernhard Vollmer and David Satz for their help. Having this mic working means a lot to me and I don't have the words to properly thank them.
More to come on this project...
Barry Hufker
Newbie
Online
Reply #12 on:
January 31, 2023, 12:09:28 PM »
Because anything worthwhile is never easy, I'm looking for a tech specializing in Schoeps microphones to finish this project for me. My local tech isn't experienced with microphones enough to handle this and I realize the only way this is going to finish is with someone with more expertise in this area. Does anyone have someone they can recommend? I personally am hopeless at anything mechanical...
klaus
Moderator
Hero Member
Offline
Reply #13 on:
January 31, 2023, 12:57:14 PM »
Hello Barry,
Once you found that U.S.-based Schoeps tech, please let everyone know.
To my knowledge, Posthorn, the original (and still?) U.S. Schoeps importer sent all mics back to Schoeps in Karlsruhe. If that has changed, I'd like to know.
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
Barry Hufker
Newbie
Online
Reply #14 on:
January 31, 2023, 10:32:25 PM »
Klaus,
Redding Audio is the current Schoeps distributor, and the people I contacted initially for this repair. They would have sent the mic to Schoeps. As Schoeps does not repair the CMTS501 any longer I've had to look elsewhere. I will post here if I find someone who is worthwhile.
Barry
Print
Pages: [
1
2
All
Go Up
« previous
next »
R/E/P
(Moderator:
klaus
