July 02, 2022, 10:55:54 AM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
R/E/P
Klaus Heyne's Mic Lab
(Moderator:
klaus
Neumann Power Supply Corrosion
« previous
next »
Pages: [
1
2
All
Go Down
Print
Author
Topic: Neumann Power Supply Corrosion (Read 3462 times)
rdraudio
Newbie
Offline
Real Full Name: Mark Cochi
on:
January 13, 2021, 08:45:16 PM »
Hi Klaus,
I've moved on to my other M269, which has a NN48hu power supply. I am yet to go through and measure voltages with the mic hooked up, but opened the power supply to test voltage and found quite a mess. I believe this has been discussed here before, and will search. I believe that this still has the Stabilyt cells installed. I would like to clean all of this corrosion off, get rid of the cells, and do anything needed to get it up to snuff. The voltages at the supply with no mic attached currently read :
B+ 126.7
Filament 4.251
Thoughts on how to proceed?
-Mark
klaus
Moderator
Hero Member
Offline
Re: NN48 hu corrosion, etc.
Reply #1 on:
January 14, 2021, 04:55:07 AM »
Remove the Stabilyt cells, clean up the mess, and follow Uwe Sattler's recommended solid state replacement stabilization:
https://repforums.prosoundweb.com/index.php/topic,37395.msg538543.html#msg538543
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
rdraudio
Newbie
Offline
Re: Neumann Power Supply Corrosion
Reply #2 on:
January 23, 2021, 10:06:31 AM »
OK...so something is not right. I removed the cells, and did the best I could to clean up the mess and corrosion. I built Uwe's circuit, and decided before hooking all back up, to make sure that everything was still ok in the power supply.
From the schematic I can find online (NN48a, mine is a NN48hu ) voltages are not good. I am reading 36V @ R7, as well as where the circuit would connect, and at Pin 4 of the connector ( obviously not hooking up a mic! ) B+ still at 127, unloaded. The voltage, even without the circuit shouldn't be that high, should it?
Mark
klaus
Moderator
Hero Member
Offline
Reply #3 on:
January 23, 2021, 12:42:31 PM »
Mark, I'll let Uwe chime in with his voltage calculations of an idle power supply that has been converted to his heater circuitry.The LM317 should regulate the heater voltage quite well, so something went wrong in your implementation.
In the meantime, if you look around on this forum, a while ago someone posted the dummy load resistor value that simulates the current draw of an AC701 tube. Connect that load and then measure again.
By the way, the B+ /high voltage you measured seems about right for AC701 power supplies without load.
Klaus Heyne
German Masterworks®
rdraudio
Newbie
Offline
Reply #4 on:
January 23, 2021, 01:03:29 PM »
Thanks Klaus. Yes, the B+ didn't change, but as I posted earlier, I was close to the 4V even with no load for the filament...but this is crazy high. Something has changed. Would the supply voltage be that different without the stability circuit of any kind? According to the schematic, no. Anybody have an idea what would cause this? I hope Uwe responds. I appreciate all the answers.
Mark
rdraudio
Newbie
Offline
Reply #5 on:
January 25, 2021, 02:24:00 PM »
OK...So I hooked the old cells back up, and voltage at the supply is fine, filament at 4.1V unloaded. Then I hooked up my new circuit. Pin 4 is not 4V, but still very high 30+ V...but at test Point 2 on the circuit, I get a slow ramp up to 4.15V, so obviously the board I built is correct, but I am missing something in the hookup. I am hooking it up like the cells were, but when I look at the schematic, I am now assuming that TP2 should go to the red where the old cells were wired, being the ramping voltage out, and I should get the input to the circuit from?
klaus
Moderator
Hero Member
Offline
Reply #6 on:
January 25, 2021, 02:34:00 PM »
I find it hard to comment without having a clearer idea how exactly you wired the work-around heater stabilization circuit.
The LM317 voltage regulator is pretty self-explanatory. There's an input, a regulating tap and an output. If you do not get the correct output, make sure you are within the voltage limits of the LM317 input.
Klaus Heyne
German Masterworks®
rdraudio
Newbie
Offline
Reply #7 on:
January 25, 2021, 10:33:26 PM »
I understand. The LM317 is wired correctly, and working correctly. I've used them in other applications. If I were to wire in Uwe's citcuit, feeding input voltage from the former Red Wire position that was used by the NiCd cells, and then take the circuits output and wire to pin 4 of the tuchel, it would work, but I don't know if this is integrated correctly. Based on Uwe's circuit, I am confused about how it integrates into the NN48. With the cells in there, there were 2 wires. I am assuming that this wires the same way. My confusion is that without anything in there, the filament, at Pin 4 of the tuchel, or at any point on the board, is approx 30V. With the cells in there, it's 4.1. With my circuit board, it's ramping, but up to a high voltage. I am missing something, and most likely something obvious.
rdraudio
Newbie
Offline
Reply #8 on:
January 25, 2021, 11:07:59 PM »
OK....been looking at this all night...and I tried this, and voltage is 4.17 unloaded at Pin 4!!! I lifted the resistor to try it ( The one perpendicular to R8 ) The white wire bridge looks like it just connects the left tab to the right, which goes to pin 4, so I assume I could also just wire to the right tab with the yellow wire. Is this the correct way to do this? This is an NN48hu, which I can't find a true schematic for. I am getting 126.7 B+ and 4.17 Filament unloaded.....
klaus
Moderator
Hero Member
Offline
Reply #9 on:
January 26, 2021, 01:36:49 AM »
The hand-wound resistor on the white plastic board was the heater fine-adjustment with the Stabilyts installed. You can either leave it, and use any of its 3 tabs or fine adjustment as well, or bypass it if you just use the trim pot of the LM317 circuit.
Overall, it looks like you finally solved the problem!
Klaus Heyne
German Masterworks®
rdraudio
Newbie
Offline
Reply #10 on:
January 26, 2021, 10:15:25 AM »
Thank You so much for all of the help. I guess if I had known what that was, (a hand-wound resistor) it might have been easier.
This does show the simplicity and how well the cells worked! So, last question: can the hand-would resistor be removed?
klaus
Moderator
Hero Member
Offline
Reply #11 on:
January 26, 2021, 11:50:38 AM »
Hand-wound resistor can be removed when installing the LM317 circuit.
Original schematic of NN48hu sent
Klaus Heyne
German Masterworks®
rdraudio
Newbie
Offline
Reply #12 on:
January 28, 2021, 11:06:25 AM »
Well...I thought this was finished. Checked all voltages, all good unloaded. I connected my M269....Filament only gets up to 2.8V....checked all wiring, all good. Tried different cable between mic and supply, same result. Tried different M269...same result. Reconnected old cells in place of new circuit...same result. So, any advice on where I should be looking? Obviously the mic load is drawing down somewhere...is there an obvious place to look? Thanks, and sorry to reopen this already too long thread.
-Mark
klaus
Moderator
Hero Member
Offline
Reply #13 on:
January 28, 2021, 02:30:03 PM »
This should be easy.
Measure and note idle heater voltage at several test points: at (+) output of rectifier, after first dropping resistor R7, and so on.
Then do the same, but with the load (mic) connected.
Then note at what point/component an unusually large voltage drop occurs.
Then test that component, to confirm whether it performs as specified, and if not, substitute it.
And if there is enough voltage at the input of LM317, let us know why the trim pot that adjusts the regulator's output does not give you sufficient range.
Klaus Heyne
German Masterworks®
uwe ret
Jr. Member
Offline
Real Full Name: Uwe Sattler
Reply #14 on:
February 02, 2021, 04:50:30 PM »
Sorry for jumping on this late. Check for conductive contamination of the printed circuit board. It may look clean, but the alkaline electrolyte from the obviously leaked NiCd Stabilyts has probably leaked into the phenolic board. If that is the case, repeatedly neutralizing with vinegar, then rinsing with water or alcohol is recommended. The equivalent AC 701 filament load is easily simulated with a 39Ω/5W resistor (exactly 40Ω/4W derived from the 4V at 100mA heater requirement). The LM 317 solid state Stabilyt replacement circuit has been successfully deployed in dozens of old microphone power supplies. Please check the DV potential at GR2 (B30/C250). With old age and possible contamination these selenium bridge rectifiers are known to develop rather high internal resistance, which will drop the available DC-voltage under load. When replacing it with a suitable silicon bridge, make sure to add an inrush-current limiting resistor of 47Ω.
Print
Pages: [
1
2
All
Go Up
« previous
next »
R/E/P
(Moderator:
klaus
