Author Topic: K67 Style Capsule vs CK12 style capsule sound?  (Read 1036 times)
MSR74
  • Real Full Name: Mickey Rogers
« on: July 24, 2020, 10:15:31 pm »
This is a really ignorant question so please don't flame me.
Why do the K67 styled capsules sound different than a CK12 style capsule? I tend to prefer a 251 styled mic or even a C12 styled mic over a 67, 47. I mean, I know that fundamentally they are built differently, Acoustically, what makes them sound different? So I guess I tend to prefer the sound of a CK12 styled capsule vs a K67 and an M7 etc. Perhaps I prefer the Austrian sound to the German sound. I don't know...
K67 styled capsules sound a certain way while CK12's are different. I use "styled" because I personally have never used mics with actual Neumann or AKG parts, so I can only comment based upon my experience with "styled" caps, although I had UM 92.1S and didn't personally care too much for it on my voice. Maybe my voice just resonates better on CK12 (style) caps (and their circuits)? I knoww the mic is the sum of it's components.
Thanks.
Kai
Re: K67 Style Capsule vs CK12 style capsule sound?
« Reply #1 on: July 25, 2020, 12:58:09 pm »
...I use "styled" because I personally have never used mics with actual Neumann or AKG parts, so I can only comment based upon my experience with "styled" caps, although I had UM 92.1S ...
There might be one mic that you can possibly afford, that is close to a true C12:
The AKG C414 TL II, or its current version, the AKG C414 XL II.
The treble boost is a bit lower pitched and less pronounced than the original C12, bass and proximity effect a bit stronger, but might be worth a try.
Combined with a tube preamp and a bit more sparkle dialed in by EQ it's not too bad.
The AKG C12 VR - AKG's own reissue of the original tube powered C12 - missed to hit the spot, I wouldn't recommend.
MSR74
« Reply #2 on: August 17, 2020, 09:57:21 am »
Hi Kai.
Thanks for your reply.
From what I have heard, it seems there is a difference in the mids- on a U67 maybe a little more pointed and present, while the ELA M 251 exhibits a slightly more broad sound.
Am I hearing accurately?
Kai
« Reply #3 on: August 19, 2020, 04:00:49 pm »
I think it's more than just some static tonal differences, even more with close miking.
There are so many factors a microphone reacts on, for example, what happens with changes in distance and angle someone sings or plays into it.
AKG and Neumann have a different house sound that comes through with most of their products.
This reminds me to a session where I had a really great singer, and when we came to choose the right microphone for the recording we ended up with an AKG.
She commented: "I always did sound good on AKG".
My thought was, she sounded great on every microphone we tried.
But she was right, the microphone complemented nicely with her warm alto voice.
mbrebes
  • Real Full Name: Michael Brebes
« Reply #4 on: August 22, 2020, 11:54:56 am »
To answer your original question, the main difference between K67 style capsules and CK12 capsules lies in the differences in construction.  K67 capsules are center terminated, where there is a screw in the center of the diaphragm  which pulls the tension at the center.  Most vibrations of the diaphragm are between the outside edge and the center.  The CK12 capsule is only edge terminated so the diaphragm can vibrate  from any edge point to another edge point, creating quite different combinations.  Differing hole patterns in the backplates also can affect the tonal responses of the diaphragms.
klaus
« Reply #5 on: November 21, 2020, 04:29:20 pm »
...and don't forget the special "resonator" plates with their scooped dish shape which AKG added to the backplates of all CK12 capsules. They significantly affect the capsule's upper midrange
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
