Author Topic: Soundcraft series 500  (Read 1945 times)
Jean moulin
  • Real Full Name: Jean-Louis Colonne
« on: March 15, 2016, 08:47:29 pm »
Hello,
 I have a 32x8 Soundcraft 500 series mixer that is getting repaired and I am trying to figure out what converters I should get.
My budget is about 1500-2000 and I am ok with  recording just trough tracks 1-8.
So my question is about the signal flow.
If I get for example a Lynx Aurora 8
I hook up my first 8 tracks in the mixer to Analog  In 1-8 Lyxn (Would be my TO TAPE)
And the Analog OUT  1-8 from lyx to 9-16 in the mixer (Would be my From TAPE)
So now where I get confused is here:
I need to use 2 tracks from the Lynx Analog OUT for my monitoring right? it means for my summing I will use 9-14 (So 6 tracks only) and 15-16 for monitoring for example, if I am right....
Now from here on, I am not pretty sure of what I need to do to bring my summing back into the Daw to a Stereo track.
And once I have my mix, I know it is not the better way to do it but I would like to treat that Stereo mix trough 2 tracks in the mixer, a sort of mastering using the eq from the board.
Also it seems to deafeat the purpose if I have to go back to the daw after summing an then come back for the Last treatment.
I tried to be clear in my explanation. I hope it is.
thank you for your time and help.
Fletcher
Re: Soundcraft series 500
« Reply #1 on: March 16, 2016, 09:31:53 am »
Are you using an actual tape machine?   If you're using a DAW you can route within the software to where ever you're going to 2 try -- if you're actually using a tape machine then take the "2 Mix" analog output and run it to your mix machine.
Peace
CN Fletcher
"Recording engineers are an arrogant bunch
If you've spent most of your life with a few thousand dollars worth of musicians in the studio, making a decision every second and a half... and you and  they are going to have to live with it for the rest of your lives, you'll get pretty arrogant too.  It takes a certain amount of balls to do that... something around three"
Malcolm Chisholm
