Author Topic: Noise problems when transferring from a Mini Disc player  (Read 4110 times)
Thomas W. Bethel
  • Real Full Name: Thomas W. Bethel
  • When only the best will do.
« on: September 23, 2015, 01:04:47 PM »
We are transferring some Mini Disc to CDs for a client. We are recording them out of our MDS-JB940 Sony Mini Disc digital using the Tosslink output into our RME 9632 audio card and recording them on Wavelab at 44.1 and 24 bits. We are getting semi regular, very short very low in intensity clicks on the files. Just to make sure we used the same setup to record a CD onto the computer off our Music Hall MMF CD-25 and no clicks or pops. On the MD player we used Tosslink and on the CD player we used SPDIF.  I am wondering if this is a clock issue or something else? Our RME card acts as the master clock and we don't have a separate word clock.
These clicks are very low in intensity and are less than 1 MS long.
Any thoughts or suggestions?
Thanks in advance...
Thomas W. Bethel
Managing Director
Acoustik Musik, Ltd.
http://www.acoustikmusik.com/
Celebrating 29 years in business in 2024
When only the best will do...
John Scrip - MASSIVE Mastering
  • Real Full Name: John Scrip
Re: Noise problems when transferring from a Mini Disc player
« Reply #1 on: September 24, 2015, 12:44:12 AM »
I'd assume you'd need to slave the RME to the MD player.  Unless the mini-disc unit has an external clock connection, it's the only way it's going to work.
The click/pop/burst thing sounds about right though (for a clocking issue).
djwaudio
  • Real Full Name: Dana J White
« Reply #2 on: September 24, 2015, 12:51:43 AM »
Yes, I would echo John's remarks.  The RME needs to sync to the Mini Disc player if you're doing a digital transfer.
I suspect you'll only see 16 bits of activity on the Wavelab bit scope as well.
Respectfully submitted,
Dana J White
Specialized Mastering
www.specializedmastering.com
Thomas W. Bethel
« Reply #3 on: September 24, 2015, 07:37:55 AM »
We do this on a annual basis for this client. This is the first time we have encountered this problem using our normal setup. I wonder why it worked for the past 10 years and now has become a problem? It would be interesting to know if the clock in the MiniDisc player has shifted slightly over time. I have to do some more investigating. Thanks for the replies.
Thomas W. Bethel
Managing Director
ggidluck
« Reply #4 on: October 07, 2015, 11:58:41 AM »
I wonder if glass fiber cables would make any difference. Or new ones for that matter.
Thomas W. Bethel
« Reply #5 on: October 08, 2015, 07:31:03 AM »
It was indeed a clocking issue and when I clocked off the Minidisc the noise went away.
Thanks for the help and suggestions.
This is a GREAT resource when having problems.
Thomas W. Bethel
Managing Director
djwaudio
« Reply #6 on: October 09, 2015, 12:32:47 PM »
Thanks for the follow-up, and glad it worked out well.
Dana J White
Page created in 0.225 seconds with 20 queries.
