Pages: 1 [2] 3  All   Go Down
Author Topic: Neumann U67- capsule original or not?  (Read 11372 times)
klaus
Re: Neumann U67- capsule original or not?
« Reply #15 on: January 07, 2016, 07:19:11 pm »
To my knowledge (Klaus can confirm), the K870 and K67 are identical.
Correct.
If it IS a true K87 we're talking about, the difference between the K870/K67 is that the backplates on the K87 are electrically insulated from one another. I'm not sure the difference that would make in a U67, but I bet Klaus knows.
You can use a K87 in a U67 as long as you connect a wire between the two (insulated) backplates, to make it one.
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
duskb
« Reply #16 on: January 08, 2016, 01:07:53 pm »
Dusk,
I'm afraid I must disagree with your advice to go with a re-skinned capsule as a cost saving measure. Re-skinned Neumann capsules represent, to me, a very poor value in comparison to a good Neumann (original) capsule, even if the fully-original Neumann capsule is more expensive. I have never heard a re-skin that sounded "right" or even especially close to it, even by the "best" re-skinners.
To my knowledge (Klaus can confirm), the K870 and K67 are identical, so there's no reason to act rashly.
Brad,
I didn't realize that the K87 and K67 were acoustically and physically the same capsule. All else being equal I would agree that one should go for new (or NOS) when possible, rather than a re-skin. I was left with the impression years ago that they were different capsules. OTOH, I think you should listen to my reskin before dismissing the value of the service. I have two otherwise original 67's, both of which I certainly can't tell apart in a blind test, when comparing the capsules. I have had a few other engineers comment on this too. I seriously doubt even few could tell them apart.
FWIW, for some capsules its a moot point anyways. For the CK12, KM5x series, M7, etc) it's either re-skin or throw it in the trash.
Dusk Bennett
Engineering/Production/Technical Services/Educator
Los Angeles Ca
Award Winning Engineering
www.duskbennett.com
klaus
« Reply #17 on: January 08, 2016, 04:43:59 pm »
Brad,
I didn't realize that the K87 and K67 were acoustically and physically the same capsule. (...) I was left with the impression years ago that they were different capsules.
They are not physically the same capsule (in K87 insulating, rather than conductive, backplate spacer material, additional insulating sleeves over the backplate mounting screws), but they are dimensionally and sonically identical during any given capsule era.
Klaus Heyne
German Masterworks®
soapfoot
  • brad allen williams
« Reply #18 on: January 08, 2016, 05:31:08 pm »
Brad,
Sounds interesting, Dusk. I wish I was close enough to you to hear it.
I've heard a Thiersch M7 reskin and a Drefahl K47 reskin.  Neither of them approached the sound of a good original. In one case (I won't say which), it was on a mic that was a candidate for purchase, and was so obviously inferior to expectations that ensuing questions revealed the reskin.
duskb
« Reply #19 on: January 08, 2016, 05:58:47 pm »
Well, next time you're in LA look me up when you have a few free hours and I'll let you hear it for yourself. I didn't realize how lucky I was that these two randomly selected 67's would work so well as a stereo pair, especially given that one was a re-skin. I've been using them for over a decade in all sorts of stereo situations and, aside from the fact that one does tend to have a buzz that I haven't gotten around to sourcing, I can't tell them apart.
I have a third in my possession with a very early serial that has a drier and tubbier sound to it. It's really nice and I believe the capsules are the same but they could not sound any more different.
Dusk Bennett
Los Angeles Ca
www.duskbennett.com
klaus
« Reply #20 on: January 08, 2016, 06:52:26 pm »
(...) I think you should listen to my reskin before dismissing the value of the service. I have two otherwise original 67's, both of which I certainly can't tell apart in a blind test, when comparing the capsules.
Who did the work? I am skeptical about claims that third-party re-diaphragming of Neumann capsules, regardless the type, would be comparabe to a healthy original. The closest (still no cigar) that anyone has ever come in my estimation is Siegfried Thiersch's nickel diaphragms for KM54/56. His Mylar and PVC work, on the other hand, I found not up to par to the sonic quality of Neumann capsules/diaphragms.
Klaus Heyne
German Masterworks®
duskb
« Reply #21 on: January 11, 2016, 02:51:20 pm »
My 67 was reskinned by Doug Walker in Canada. I would never go so far as to say that it's impossible for anyone to tell the difference but I have yet to find anyone who can (or has been able to) tell them apart. Perhaps someone who spends alot of time listening for those nuances in a controlled environment would be able to pick it out but unfortunately it's a moot point because none of you guys live close enough to give them a listen.
(BTW, that reassures me about the KM 54. I have a pair that need new skins and I've been reluctant to get them redone. They are unusable otherwise.)
Dusk Bennett
Los Angeles Ca
www.duskbennett.com
klaus
« Reply #22 on: January 11, 2016, 04:18:12 pm »
Hello dusk,
Thanks for your post. My experience with Doug's reskinning work has not been so positive. Doug, fine gentlemen that he is, in my opinion has so far not succeeded in recreating or approximating Neumann's quality of sound.
I am hopeful, though, that, given the many people who currently attempt rediaphragming, one of them will eventually succeed.
Aside of the eternal desire by all of us to save money, I am mystified why anyone would buy inferior third-party replacement products when the originals are still made.
Klaus Heyne
German Masterworks®
Jim Williams
« Reply #23 on: January 11, 2016, 04:32:57 pm »
Probably the same reason some would buy the Epiphone Les Paul over a Gibson?
I suspect for many that close enough is a cigar.
SDVIG
  • Real Full Name: Sergey Kazantsev
« Reply #24 on: June 10, 2016, 08:22:24 am »
Hello everybody.
I got access to the microphone, and I want to continue.
The microphone was repaired.
It was the replacement of one resistor 2.2 megohm to 2 resistors - 1 megohms & 1.2 megohms. (russian mlt resistors)
As a result, I watched three stages mic life.
A) The microphone worked and had a certain sound.
B) The microphone worked and had the same particular sound, but the low output level.
C) The microphone was fixed and running, but it has a different sound and a normal output level.
The microphone was repaired a specialist in musical equipment,
but he is not the master of the microphone.
He checked the voltage, and said that everything is within the permissible norm.
Interestingly replacement resistor could so dramatically change the sound of the microphone?
The sound of the microphone before repair I liked more.
But I'm not sure.
Why paragraphs A) and C) do not match?
PS:
The head is not touched during repairs.
SDVIG
« Reply #25 on: June 10, 2016, 08:24:07 am »
Schematic & Resistor
klaus
« Reply #26 on: June 10, 2016, 09:03:53 am »
Hello Sergei,
Was the original 2MΩ resistor positively identified as faulty?
I am unclear why you are saying that somehow now the mic sounds different: In your opening post, you mentioned that you do not have a second U67 to compare the sound of yours to. I understood that to mean that you never heard your mic at full output, and with an original Neumann capsule until these repairs were done?
Replacing either resistors R12 or R13 with 2 smaller ones in series is fine, and would not have changed an original U67's sound. I suspect, that your technician may have done other things to the mic, or, more likely, that, because you had never heard your U67 with an original capsule until these changes were made, you had no good comparison.
Klaus Heyne
German Masterworks®
SDVIG
« Reply #27 on: September 27, 2016, 07:57:36 am »
Hello Klaus.
I really can not compare the sound of my 67 with another 67.
I plan to install it in other capsules.
I see at ebay 2 offers.
Can you help me identify capsule with red numbers:
http://www.ebay.com/itm/322267213326?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
because with black you have already done so.
http://www.ebay.com/itm/282186430784?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://repforums.prosoundweb.com/index.php/topic,36282.msg536154.html#msg536154
Thanks for the help.
A side:
SDVIG
« Reply #28 on: September 27, 2016, 11:27:37 am »
B side:
klaus
« Reply #29 on: September 27, 2016, 02:12:19 pm »
The build characteristics point to a 1990 version.
Make sure the seller tucks away the two solder shoes at the ends of the lead-out wires before shipping. As shown, they are dangerously close to the diaphragm and can easily rip it.
Klaus Heyne
German Masterworks®
Pages: 1 [2] 3  All   Go Up
