Author Topic: Help with Neve 2264 mod  (Read 2630 times)
pacoloco
« on: November 07, 2014, 10:32:03 am »
Hi
Mi have a Neve bcm and i have two channels e play and i want to put 2 2264 but i have to make a mod and i cant remember how is,somebody here who clan help me with this? I know is something very easy but i cant remember
 Thanks
Geoff_T
Re: Help with Neve 2264 mod
« Reply #1 on: October 20, 2015, 02:15:16 pm »
Hi
Not been to this site for years and found this post.... surprising nobody replied!
Just plug it in to any channel slot and use the line input connection. If your desk is modified for channel outputs you will get a balanced channel output from the 2264 but the signal it will send to the busses will be 4dB lower.
If you want the stereo links to work you will need to link the pin Ms on both modules and also the pin N's.
The BCM10 is a messy configuration to plug a compressor into a channel.... you would be better off mounting them externally in a rack.
Katerin Stone
  • Real Full Name: Katerin Stone
« Reply #2 on: October 22, 2015, 08:46:20 am »
Thank you for your reply. But what if my desk is not  modified for channel outputs? What my actions should be then? :-[
Christine from writemyessay24h
