Bass drum is a good example, it will destroy an excellent U67 or the later U87 in a couple of months studio use.
No commercial studio can afford to record a drum kit rigged up with 40.000 $ worth of Neumanns.Enough dynamic alternatives that will do the job...
Enough dynamic alternatives that will do the job just as well saving the Neumanns for the purpose they are meant for.
Mikes are positioned at greater distance recording a drum kit when playing jazz.
For musical instruments what you call "break in" is undoubtly very important.A high quality condenser mic - on the other hand - is constructed with the goal that it should NOT change its sound over time.For this purpose, some critical parts of it are even pre-aged.So once it's delivered, its sound should stay the same for a long time.Breaking in with sound of any kind (except explosions) for sure wouldn't change the mic.Only environmental circumstances like very high temperature or excessive humidity or a combination of both can "break" - not "break in" - a mic.I say "break" because every change is unintentional here.Some electronic parts, specially electrolytic capacitors, can change a bit if in use after a long time with no power applied to them.This is called "reformatting", because they where already "formated" in the factory.The effect is very little and mostly inaudible, as those C's are usually not in the audio chain.Plus - it's only necessary to put power on them to do this, no special signal required.RegardsKai
negative feedback can to a certain extend compensate for changes in components... Too much n.f. is bad for your ears.
