Author Topic: What program are you using to zip files?  (Read 2236 times)
Thomas W. Bethel
  • Real Full Name: Thomas W. Bethel
  • When only the best will do.
« on: January 11, 2014, 07:38:09 am »
The program I am using to zip files is 7-zip http://www.7-zip.org/ It seems pretty good but lately I zip a 128 MB file and when I unzip it to check it it shows 124 MB file size and I am not sure why.  Sometimes it says some of the files were changed. Any suggestions would be most welcome. I use both Mac and PC but most of my mastering is done via a PC. Thanks in advance.
Thomas W. Bethel
Managing Director
Acoustik Musik, Ltd.
http://www.acoustikmusik.com/
Doing what you love is freedom.
Loving what you do is happiness.
Celebrating 25 years in business in 2020
Hermetech Mastering
  • Real Full Name: Gregg Janman
  • Manual Gain Rider
Re: What program are you using to zip files?
« Reply #1 on: January 11, 2014, 09:31:12 am »
7Zip on PC, never any problems.
BiigNiick
  • R/E/P Forums
  • Real Full Name: Nick Landis
« Reply #2 on: January 13, 2014, 01:10:49 pm »
i've used 7zip on windows before and works well for me...  on osx, i just use the native zip utility.  never really had any problems.  your file size discrepancy seems strange to me.
 - nick
ArtSta
  • Real Full Name: Artur Stawski
« Reply #3 on: January 14, 2014, 04:32:14 pm »
I rarely use 7zip, but when used, never encountered such issue with it. I believe such programs use crc to detect deflation problems, so there should be an error reported (however my 7zip does not inform that the file was extracted successfully, either).
Once I had similar problem with another program (don't remember which one), but finally found a root cause (gave it a second try)- disk full :). Of course an appropriate message popped up, but I lost it during windows switching and closing program :). Of course file was smaller than it should. Some programs leave partially uncompressed files on disk in such case, but some remove them- maybe try to check how 7zip behaves under similar conditions.
Btw. I use linux (connected to internet) utility to compress files.
Art
bkuijt
« Reply #4 on: January 21, 2014, 05:13:08 pm »
On Windows I use Winrar for zip and rar.
If I created the files I have the habbit of including MD5 checksums to verify all is identical to the source after it's unpacked.
Maybe you can try this to see if there is a discrepancy?
Bastiaan Kuijt  //  BK Audio  //  www.bkaudio.nl
KAyo
  • R/E/P Forums
  • Real Full Name: KAyo
  • Business Videos 24/7
« Reply #5 on: January 30, 2014, 03:27:41 pm »
Ditto here.
I've used a normal zip format on Windows. A zip file has a -read in and -read out error processing. If a non match occurs, the file fail safe's to corrupt. A MD5 check sum is a good idea too.
Try this resource: http://kb.winzip.com/kb/entry/41
www.kantabiz.com
Business Video Directory
