From the pictures, neither I, nor, I am afraid, anyone else can tell you in what functional condition this (I assume original-diaphragmed?) CK12 is.
But you can make a function test yourself: keep the two screens off the two capsule, plug the mic in, set it to figure eight, blow hard on both diaphragms (first one, then the other) as you observe what the skins are doing when you stop blowing: Does the diaphragm come right back to its resting position? Or does it stay stuck against the backplate for more than a second or two? If that is hard to see, take a strong flashlight to illuminate the gold sputtering during this process, for a better view.
If both diaphragms resist getting sucked against the backplate (it's called electrostatic attraction), you have a healthy capsule. If even one side gets stuck, I would not buy full price for such mic, as original well-working CK12s have become very expensive very fast as of late.
