January 18, 2021, 04:14:29 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
R/E/P
Klaus Heyne's Mic Lab
(Moderator:
klaus
414B-ULS capsule
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: 414B-ULS capsule (Read 6163 times)
aremos
Jr. Member
Offline
Real Full Name: Ariel Remos
414B-ULS capsule
on:
September 01, 2013, 11:42:36 am »
AKG, Wien (Vienna), is STILL manufacturing the capsules for the B-ULS's (and also for the EB's, & TL-II's).
Has anyone replaced their capsules recently with these?
Or does anyone have any knowledge or experience with these?
Are they the SAME?
Thanks.
klaus
Moderator
Hero Member
Offline
Re: 414B-ULS capsule
Reply #1 on:
September 02, 2013, 03:14:32 pm »
To my knowledge, both Teflon capsules (actually white Nylon® diaphragm surrounds)- the "frequency flat" CK12 Teflon, and the TLII/C12VR capsule (slight upper midrange boost) - are still in production.
If you wish I can get you the part numbers after the holidays.
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
aremos
Jr. Member
Offline
Reply #2 on:
September 02, 2013, 05:17:34 pm »
Thanks Klaus!
I just wanted to make sure that they are the same - the "frequency flat" CK12 Teflon that belongs on my B-ULS's that need replacement.
Do you know if the sound is any different ... or has anything been altered?
Ariel
klaus
Moderator
Hero Member
Offline
Reply #3 on:
September 03, 2013, 01:19:09 am »
If you mean by "the same" that the construction and tonality of the capsule used in the 414B-ULS has not changed over the years: To my knowledge, it has not.
If you mean by "the same" that the sound of the two capsules mentioned is the same: no it is markedly different.
Klaus Heyne
German Masterworks®
aremos
Jr. Member
Offline
Reply #4 on:
September 03, 2013, 11:55:06 am »
Yes, it was the former:
That the construction and tonality of the capsule used in the 414B-ULS has not changed over the years ...
the one pertaining to the TL-II sounds different because of that boost.
Thank you.
bremusound
Newbie
Offline
Real Full Name: Dirk Alex
Reply #5 on:
September 05, 2013, 05:48:41 pm »
B-ULS capsule: Part no. 2072-Z-0005
TLII capsule: 2072-Z-0009
Some info:
http://www.saturn-sound.com/Curio's/akg's%202072%20z%200005%20capsule.htm
klaus
Moderator
Hero Member
Offline
Reply #6 on:
September 05, 2013, 06:39:41 pm »
Thanks for the link. Maybe it's worth adding that the predecessor sub-versions of the current B-ULS capsule (part no. 2072-Z-0005) did not differ in their acoustic properties, but in the way, for example, how the lead-out wires were attached, or how certain internal electrical contacts were made.
Klaus Heyne
German Masterworks®
aremos
Jr. Member
Offline
Reply #7 on:
September 06, 2013, 12:30:50 am »
Great info & thanks for the part #'s ...
Dirk & Klaus.
Print
Pages: [
1
Go Up
« previous
next »
R/E/P
(Moderator:
klaus
414B-ULS capsule
