Folks tend to overthink this stuff. It's not complicated. You put up all your mics and pick the winner. If they all suck, then you borrow/rent some.
If a key change forces an unwanted resonance, you pick another mic that works better. Change styles and you may change mics again. Like potato chips, you can't have just one.
The only mic that ever came close to working for almost anyone was a modified AKG 414 B-ULS, a flat mic. Sometimes EQ was used to get it where you want it. Usually, if you have enough choices you would find a better choice than that 414, it's a vanilla sort of mic that covers many bases.
These days, that mic would probably work 90% of the time. I wouldn't stress mic selection too much, unless you have one of those amazing voices (which seem to be missing lately) that requires an amazing mic.
Are you the next Frank Sinatra or Jim Morrison? Then you should be that picky. If not, get back to work, no one but you will notice nor care.
