Author Topic: westlake bbsm10 woofers?  (Read 1519 times)
andrekbelo
« on: April 19, 2013, 11:26:12 am »
i need another help...
i need new 10" woofer for my Westlake bbsm10.... do you know if is it AUDAX or SEAS? correct model?
thanks
Andre
Fletcher
Re: westlake bbsm10 woofers?
« Reply #1 on: April 21, 2013, 07:48:59 am »
Have you checked with Westlake?  Have you read the specifications for the drivers?  I'm rather unfamiliar with what is inside Westlake monitors -- but if you read the driver specifications you should be able to land on an "after-market" driver that is equal to the efficiency of the "factory original" driver in the cabinet.
Matching the efficiency of the driver is of paramount importance in order to maintain the balance between woofer and tweeter post crossover -- a less efficient driver will net less bass in the resulting response, a more efficient driver will net more bass in the resulting response -- neither of which will give you the same response you had before changing the driver.
Best of luck with your search.
Peace
CN Fletcher
"Recording engineers are an arrogant bunch
If you've spent most of your life with a few thousand dollars worth of musicians in the studio, making a decision every second and a half... and you and  they are going to have to live with it for the rest of your lives, you'll get pretty arrogant too.  It takes a certain amount of balls to do that... something around three"
Malcolm Chisholm
