Author Topic: Dangerous Master and Monitor...any users  (Read 3790 times)
Glenn Bucci
« on: February 28, 2013, 10:19:03 pm »
These units look like great options for a mastering studio. Anyone out there use them, what are your thoughts? What do you use for metering?
Thanks
dietrich
  • Real Full Name: ds
Re: Dangerous Master and Monitor...any users
« Reply #1 on: March 01, 2013, 06:58:23 am »
Hi Glenn-
I have used the Dangerous Master for a few years now and just picked up the Monitor few weeks back. Great system. I have a pair of Crookwood Vu's. Will add an AES meter soon
Glenn Bucci
« Reply #2 on: March 02, 2013, 09:23:37 am »
How do you connect the metering to the Dangerous system? I assume the metering is connected to an output of the mastering unit..which one?
JimK
« Reply #3 on: March 02, 2013, 12:21:30 pm »
Hi Glenn, I have the Dangerous system too, including the Master, Monitor, and MQ (meters and headphone amp). The Monitor has analog and digital feeds for meters. If you look at the Dangerous website there is a photo of the rear panel of the Monitor where you can see the connections.
Jim Kissling
Glenn Bucci
« Reply #4 on: March 02, 2013, 08:44:46 pm »
Thanks for the reply. I am disappointed Dangerous no longer makes the MQ anymore. It looks great
Glenn Bucci
« Reply #5 on: March 12, 2013, 06:53:55 pm »
I heard Dangerous might be coming out with a new meter box.
Dan Lawrence
« Reply #6 on: May 13, 2013, 04:01:10 am »
Well, I know this post has been cooling off for a while, but I just started reading the mastering section, and thought I'd add a note.
I am just a home recordist, who strives to put his resources into a few select pieces of quality gear rather than tons of "consumer grade" solutions which lead to frustration or low sound quality. Before buying a monitor st, I kept thinking bout all the pre-amps, mics, or compressors I would be delaying by getting a $2000 (plus) monitor switching device.
I will simply say I have never regretted it for a moment, and I don't begin to exploit the features like talk back, aux input, LFE subwoofer options, etc. Just basic switching between four inputs and three outputs, muting L or R, mono on touch, and a level control. It has saved me tons of hassles and for that alone it's worth it.
dangerously yours,
D
dumchidumchi
  • Real Full Name: Simon Li
« Reply #7 on: August 24, 2013, 05:48:24 am »
Using Master, Liaison and Monitor ST with DAC-ST here.  Couldn't be happier for these.
Simon Li at nOiz
CbMedia
  • Real Full Name: Christopher Mahle
« Reply #8 on: November 08, 2013, 04:05:31 pm »
Monitor ST user, no external metering here, works like a charm and the remote has extreme sex appeal ;)
