Author Topic: Neumann KM86i Gotham Pad Removal  (Read 2475 times)
hasbeen
  • Real Full Name: Troy Douglas Sutler III
« on: June 06, 2012, 11:50:39 PM »
I lost the info showing exact place where the resistors would be for removal on the Gotham version of this mic. Can anyone help? I see where to strap for 200ohm but the removal of the Gotham pads eludes memory. Thanks!
Who Is John Galt?
klaus
Re: Neumann KM86i Gotham Pad Removal
« Reply #1 on: June 07, 2012, 03:27:50 AM »
Looking at the circuit board across the spot where the output impedance (50/200) is set, and separated by the transformer, you will find two thin parallel solder traces onto which are mounted two 1/8W 47 Ohm resistors.
Once you unsolder them you will see a tiny gap in the traces where the resistors were located. Fill the gaps with solder, or  solder thin bare wires across the gap, and you will be set for full output of the mic.
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
hasbeen
« Reply #2 on: June 07, 2012, 02:22:01 PM »
Thanks Klaus, much appreciated.
Who Is John Galt?
Page created in 0.034 seconds with 21 queries.
