Essentially I'd like a plugin that can do all the common things you'd find in a full featured analog mastering console in one plugin. L solo, R solo, independent L and R (or linked) +/- gain adjustments with a "bit transparent" option to move in -6.020599913279624 steps, L/R channel swap, L and R phase invert, mono button, M solo, S solo and a width knob/slider (gaining up or down "S"). I can accomplish all of those things currently but need to use a combination of like 2 or 3 plugins to do all of them. It's a workflow thing more than anything else. I think it'd be a cool plugin to have on your pitch track.
Nick,Yep. Between bx_solo, Flux Stereo Tool and Reaper I can do all of the things I outlined. I still think it'd be cool to have one plugin that could do them all.
Sounds like my Crookwood, only all in a plugin. Would be cool for working laptops "on the move" I guess. Maybe someone could custom make one for you?
I always try to use:2.71828or 1.6180339or3.14159265JT
JT -Agree with the second one which is my favorite. Oh, BTW, it's actually 1.6180339999999999......(the 9 is infinitely repeating). It does make a difference you know. How'd you forget that...?
Yes Gregg, it's its huge, & packed with information, almost a digital audio bible.I've highlighted many sections over the years.Continue to go back to it as a resource.Enjoy, best regards, JT p.s. I must add a comment, that when I'm making level changes in digital audio, I admire the purity of going "by the numbers", but the ear, as always, is really the judge!
In Samplitude you don't have to type in an exact amount. There is a button to Normalize to 50%. When you click on that it displays -6.02 in the db window.
I've not tested this plugin but I think it does the "Bit Pattern Transparency" thing.http://www.cerberusaudio.com/Software/Products/Volt/Cheers,Herbeck
