Author Topic: Adding "Fullness"  (Read 2715 times)
djwaudio
  • Real Full Name: Dana J White
Adding "Fullness"
« on: January 14, 2012, 11:56:37 am »
Just curious what you use/do to add a sense of fullness or oomph to a thin mix? I'm attempting to match a slightly edgy acoustic number to a really sweet and full rock track, miles away at the moment.
Respectfully submitted,
Dana J White
Specialized Mastering
www.specializedmastering.com
Jerry Tubb
  • Real Full Name: Jerry Tubb
Re: Adding "Fullness"
« Reply #1 on: January 14, 2012, 12:26:13 pm »
Add a bump at 50/60Hz on the Sontec with a broad Q.
Perhaps a slight nudge at 420Hz on NSEQ-FF for the vocal range.
Cut something in the upper mid; perhaps 2.8k with a surgical dig EQ
and/or DeEss at 8k with the Sonnox De Esser
Print to 1/2" analog tape before Analog EQ loop.
Did this yesterday for the same reasons as you Dana.
JT
Terra Nova Mastering
Celebrating 25 years of Mastering!
jdg
« Reply #2 on: January 14, 2012, 01:54:25 pm »
if there is no vocals, i play in the 250-400ish range.
if there is vocals, i try some saturation (550Ms pushed hard)
sometimes, i insist on putting more space between the two tracks instead
John McCaig
-the caption captain
Allen Corneau
  • Real Full Name: Allen Corneau
« Reply #3 on: January 14, 2012, 02:13:56 pm »
Did 3 songs recently where all three mixes were thin and edgy.
What helped tremendously was the Massive Passive, boost/bell with widest Q; 330Hz for 2 songs, 270 for the other. Cranked it up to 11 or 12 o'clock, which with the widest Q was probably about 2 to 3dB.
Added some bottom with the API 5500 as well, but only 0.5 to 1dB.
Allen
Allen Corneau Mastering
http://allencorneau.com/
Treelady
« Reply #4 on: January 14, 2012, 05:50:16 pm »
This is one of the few times you have license to go wild with EQ.  You may need to cut highs you would never dream of touching or at gain steps you never normally go to...
______________________________________________
Garrett Haines
Chief Mastering Engineer, Treelady Studios, Pittsburgh, PA
Senior Contributor, Tape Op Magazine
Cass Anawaty
« Reply #5 on: January 14, 2012, 08:59:28 pm »
Parallel compression targeting the 200-400 range (not normally into this sort of thing).  The UA Fatso works great for me, and allows the attenuation of the highs to keep the edge out of the vox.
Cass Anawaty, Mastering Engineer
www.sunbreakmusic.com
pmx
  • Real Full Name: Paul Matthijs Lombert
« Reply #6 on: January 15, 2012, 05:43:15 am »
mass pass in the 330 and sometimes 390 bands gives a lot of body, 3 gain steps most of the time, or a db or so of 150 hz shelf on the 2055.
Paul Matthijs Lombert | The Mastering Factory
djwaudio
« Reply #7 on: January 15, 2012, 09:19:59 pm »
Thanks for the ideas, going in Monday with with a fresh ear should help too. Agree on the massive passive low miss, wish I had one in this room.
Dana J White
djwaudio
« Reply #8 on: January 16, 2012, 11:23:08 pm »
This is just what I ended up doing, a dB of HF shelving cut on the SPL at 580 Hz, and brought back some 15k with the Prism. Popped right into place. A bit of de-essing and a little trim in the lows, fast attack on the comp to eat some of the edgyness. Fat city!
Dana J White
Jerry Tubb
« Reply #9 on: January 17, 2012, 10:08:35 am »
Agreed with the concept of "it depends on the project".
Knowing your gear, where to make cuts/boosts on which EQ, slight compression tweaks, etc. Only comes from experience.
The ear is the final judge.
Best, JT
Thomas W. Bethel
  • Real Full Name: Thomas W. Bethel
  • When only the best will do.
« Reply #10 on: January 18, 2012, 08:02:44 am »
Best, JT
Good call
Different strokes for different material and the ear is always the final arbiter when it comes to what sounds GREAT.
It is amazing how a good mastering engineer can find the sweet set of frequencies that will bring the music to life and how that set of frequencies can change depending on the material. IMHO lots of experience plus GREAT equipment plus a GREAT room make all the difference.
Thomas W. Bethel
Managing Director
Acoustik Musik, Ltd.
http://www.acoustikmusik.com/
Doing what you love is freedom.
Loving what you do is happiness.
Celebrating 23 years in business in 2018
