Update: I think I may have a worn out/dying laser. On some discs, instead of the drive doing what it's supposed to do I get two amber blinks, which according to this chart* says "the drive cannot properly configure the focus and track adjustment settings".Grrr...* http://www.plextoramericas.com/index.php/faq/28-general-optical-faqs/240-blink-codes-for-the-px-716a
Speaking of EAC........I used it all the time in XP but cannot get it to work in Win7. Anyone else had any luck with it? If so, which version?Thanks.JL
Hey Allen,have you run the "Self-Test" procedure on the drive?
If you're in a bind, I could send you one of mine. Really.JT
I'm going to try cleaning the lens (if I can get in the damned case!) and if that doesn't work I'll move on from there.
Latest version of EAC working fine on Win 7 64 bit here!
Is this the one that's working on Win7...?Exact Audio Copy 1.0 Beta 3 (International)
Ran it last night and it failed: "one green blink indicates a write or read error".I appreciate that Jerry. I'm going to try cleaning the lens (if I can get in the damned case!) and if that doesn't work I'll move on from there.
Opening the case, although it looks to be a mystery is quite easy, it all starts with that little screw on the back, then slide the top/bottom off...Here's a nice play by play article w/ pics, on cleaning the lens:http://www.patrickmin.com/linux/tip.php?name=plextorJT
http://www.plextor-digital.eu/index.php/component/option,com_jdownloads/Itemid,0/catid,86/cid,470/task,view.download/There you go.Chris.
