R/E/P > Klaus Heyne's Mic Lab
Fitting a k87 capsule without the leads already attached
<< < (2/2)
ssltech:
Thanks for the clarification, Klaus.
Keith
africantigercow:
Quote:
P.S.: the dent in the diaphragm is not nice. While it does not look like a hole (bad for the damping of diaphragm movement), its depth may interfere with the free movement of the diaphragm against the back plate, which is only 40
ssltech:
There's nothing that can be tested without hooking it up electrically to SOMETHING... -So I'd proffer that it might be a good idea to hook it up and have a listen.
Even if it's touching the backplate at rest, it still won't stop it from producing sound, it would just alter the free movement of the diaphragm to a greater or lesser extent... think of a tapping drum skin with a finger gently touching it in one spot as an analogy.
-It might be quite acceptable, and if you turn it so that it's the REAR diaphragm surface, it wouldn't have any significant effect in cardioid; just omni and fig-8.
I've certainly had a diaphragm which had a similar dent, which the owner was entirely happy with... and it was on the FRONT diaphragm. -Your mileage may indeed vary.
As for cleaning; I've seen worse capsules be perfectly fine, and it'd be impossible to judge merely by the picture.
You be the judge; -try it, and see.
Keith
MagnetoSound:
If you're very lucky, that dent could be right over one of the holes in the backplate and be no trouble at all.
Or it might not.
africantigercow:
Thanks very much for your help everyone.
I guess the best thing to do is to slap it on my mic and see how it sounds...
Navigation
[0] Message Index
[*] Previous page
Go to full version
