adoucette wrote on Mon, 10 January 2011 11:38 |
Hello,
Been awhile since my last post, been a little crazy around here!
I've been experimenting with using EQ on my mix bus about half way through a mix. I wanted to know if anyone else is using this formula and if perhaps you had some further pointers or interesting ideas about it. I basically start by getting as balanced of a mix as I can using just volume pan and filter EQ's to remove anything that isn't necessary. Once I am content that I've got a relative balance of instruments I will reach over to the mix buss EQ and and start massaging out a few different ideas. Basically I will just EQ the 2bus until the track has more character, brighter, clearer etc. Once i've done this I find the few fundamental items that need extra processing with come to light. Usually some of the drums if the play is a little inconsistent and then the bass and vocals. Of course it varies dependent on the mix but just as a general flow that's often how it seems to work. I find once I've done this I can set my mix bus compressor to limit some of the overages, add a bit of depth using some FX and the general mix is done. I finish up by automating a bunch of sections and then print it for the day and review at home.
Any sort of destructive things I should be aware of by this method? It seems like a good method to me. Which I know most of you will say is all that counts haha. But i'm curious from a more experience mind than mine if this method is tried and tested and what the end thought was on it.
I usually have been going for the Trident A-range EQ on the mix bus and if I need something a little more versatile I will reach for more of a mastering based parametric. The A-Range has great character to the top end though, beautiful EQ. Mix bus comp is a SSL X-Logic 4000 series bus compressor.
Thanks,
Andre,
Anything you can do to make your mixes independently better is better. If you compare you mixes and expect the mastering engineer to make them brighter, why would you not make them brighter yourself?
I grew up in live broadcast and there are no mastering engineers following you around with a compressor and equalizer fixing up your mixes, only that dumb ass in the production truck with a broadcast limiter with a fifteen second release time that he barely notices during the show. So I got used to making my mixes broadcast ready, by myself.
I read all the time of mastering engineers who just touch up a mix with a .5 db here and a .5db there. They love it! Be one of the guys that give them mixes they don't have to screw with much and you will get praise (and gigs)from them.
However, EQing your mix buss has lots of pitfalls. For example, when you slap on that 10Khz eq to brighten up the drums, when you get home, the vocals will be sibilant, not really a step forward. So make your mixes, use a reference and EQ to taste.
One last thing. DON'T hypercompress your two buss unless you are going to the broadcast truck and it's exactly what you want. This is because you can't undo compression. Just won't happen. And if you do end up going to a real ME, he won't be loving you for that, because his hands are tied.
Best regards,
Bill
