The balanced AES/EBU digital format...
The mix from my desk feeds an AD-824 module in a Lavry 4496 chassis. I return the digital output of this to a couple of the AES inputs on one of our Rosetta 800s for mixdown to Protools. However, the desk has no balanced 2-mix inserts, so I prefer to put any 2-mix processing inline between the desk output and the AD. This is great, except it does not allow for monitoring of the 2-mix processing. Up until now, I have mixed to a pair of bus outputs in the desk and looped this mix back to the board for monitoring, tying up precious real estate.
I would like to split the AES signal to allow for simultaneous mixdown and monitoring through the Lavry DA-824, which can then be fed back into the desk's alternate 2-mix input. Push a button to hear 2-mix processing.
Can I just make an AES mult cable, or is it not that simple?
Thanks.
