Pages: 1 [2] 3  All   Go Down
Author Topic: High/low pass  (Read 11430 times)
Waltz Mastering
Re: High/low pass
« Reply #15 on: December 06, 2010, 12:05:37 pm »
Patrik T wrote on Sun, 05 December 2010 13:36
Maybe 20-30-50-80 could be a good spread for me?
Bax is selectable: Out, 12, 18, 24, 30, 36, 43, 54Hz (3dB down point, 12dB/oct)
Adam Dempsey
Re: High/low pass
« Reply #16 on: December 13, 2010, 07:16:34 pm »
I'm actually quite surprised that the HPF's in the MTC-2 console are so high (the lowest being 20Hz). The manual doesn't state how steep they are. Comment from any MTC-2 users? Or any who've had them modified?
Adam Dempsey
Jack the Bear's Deluxe Mastering
Facebook | twitter | MySpace
Add presence, or subtract absence?
Gold
Re: High/low pass
« Reply #17 on: December 13, 2010, 08:38:55 pm »
The MTC-2 is designed to be used as a cutting console. Being dainty about an HPF is often not an option or simple a matter of taste.
Paul Gold
www.saltmastering.com
On the silk road, looking for uranium.
Laarsø
Re: High/low pass
« Reply #18 on: December 14, 2010, 03:00:39 am »
Gold wrote on Mon, 13 December 2010 19:38
Apparently the MTC-2's "garbage disposal" filters are crippled against half-schpeed cutting, in which case you would need to be able to go down to 10 cycles, yes?
Laars
Space Camp Mastering
laarsoglethorpe@gmail.com
"Lack of DSD post filtering fried a lot of expansive twitters." (D. L.)
Gold
Re: High/low pass
« Reply #19 on: December 14, 2010, 09:47:01 am »
Laars
Paul Gold
Adam Dempsey
Re: High/low pass
« Reply #20 on: December 14, 2010, 08:21:49 pm »
Gold wrote on Tue, 14 December 2010 12:38
Yes, although it seems equally intended for general mastering. If the filter is 6dB/oct it'd significantly eat into the passband, and if higher than 20Hz (as all its other filter selections are) many of us would agree the mix has serious issues. So, purely curious if any MTC-2 users had specified other filter options, especially as, when engaged, it's designed to condition the signal prior to any further routing, including the optional elliptical filter.
Adam Dempsey
Gold
Re: High/low pass
« Reply #21 on: December 14, 2010, 11:26:07 pm »
Adam Dempsey wrote on Tue, 14 December 2010 20:21
I would argue the opposite. If the mix falls apart because you put a 40Hz HPF then the mix has serious issues.
Paul Gold
Bonati
Re: High/low pass
« Reply #22 on: December 14, 2010, 11:56:10 pm »
If the MTC-2 HPF/LPF and Stereo width/EE sections were available as a separate box I'd buy it in a heartbeat. Wish I could afford the whole hog.
Josh Bonati
Brooklyn, NY
www.bonatimastering.com
Laarsø
Re: High/low pass
« Reply #23 on: December 16, 2010, 08:54:52 am »
Gold wrote on Tue, 14 December 2010 08:47
Laars
Geoff Emerick de Fake
Re: High/low pass
« Reply #24 on: December 16, 2010, 06:15:29 pm »
Andrew Hamilton wrote on Sun, 05 December 2010 01:30
 However, what I'm looking for are several corners that are between 10 and 20 Hz.   I'm thinking about something like, 10, 12, 14, 16, 18, 20, and maybe the double-deuce (22) found on the stando massivo.
Tsch
Gold
Re: High/low pass
« Reply #25 on: December 16, 2010, 06:17:46 pm »
Laars
Paul Gold
dietrich
Re: High/low pass
« Reply #26 on: December 17, 2010, 07:28:32 am »
Bonati wrote on Tue, 14 December 2010 23:56
Laarsø
Re: High/low pass
« Reply #27 on: December 17, 2010, 07:53:29 am »
Gold wrote on Thu, 16 December 2010 17:17
Laars
Andrew Hamilton
Re: High/low pass
« Reply #28 on: December 17, 2010, 08:14:23 am »
Geoff Emerick de Fake wrote on Thu, 16 December 2010 18:15
Tsch
www.serifsound.com
premastering for CD and DVD-A.  Featuring FTP load in and delivery as well as analog tape transfers.
Re: High/low pass
« Reply #29 on: December 19, 2010, 11:43:11 am »
Andrew Hamilton wrote on Fri, 17 December 2010 07:14
If filters had no effect on the parts of the spectrum that lie outside their bandwidth (Q), I'd settle on a 20 Hz switch.  But when I invoke any (natural) filter down at 20-ish, there's usually too much taken away from the good bass up through the low mids.
Then these filters have a serious design or implementation flaw. Having to shift the corner frequency nearly an octave away in order to prevent it gnawing at the useful range is extreme.
Pages: 1 [2] 3  All   Go Up
