Author Topic: Limiting HELP  (Read 1856 times)
nalbi
Limiting HELP
« on: August 19, 2004, 03:27:22 pm »
Hello All!
I'm self-educated in mixing mastering.
I play on guitar generally.
I have some questions about
final mastering proces...or mixing i don't know....
about limiting
here some pictures from wave lab
1st one is Pro mix artist Dave Marton
Candian Guitarist
http://www.nalbi.hotbox.ru/good.jpg
2nd is my mix but my limiter always
http://www.nalbi.hotbox.ru/bad.jpg
CUT out peaks
this is hapen when i try to get some Loudness
-12 RMS or -11 rms
I push treshold on my limiter but my peaks
begin look ugly......
I'm have lack of knowledge of Ifundamental rules in
Exporting levels in my CUBASE SX , mixing levels in output bus
You know......
Here in Bulgaria There is no place where to study
basis of mixing and exporting and
mastering....
Sorry about this beginner questions
What I must to do
What is your masterin chain
Pls give me a principal base to start
what level for export in peak meter in Cubase
Then bus compression or .......I dont know
Im Sorry for that
regards with respect
SORRY FOR MY unlettered questions.
here some audio clips
http://nalbi.hotbox.ru/Dimitar_Demo2 .mp3 - my personal mix and track
http://nalbi.hotbox.ru/Dimitar_Demo1.mp3 - my personal mix and track to
http://nalbi.hotbox.ru/dave_marton.mp3 original track
Dimitar Nalbatov
OTR-jkl
Re: Limiting HELP
« Reply #1 on: August 19, 2004, 05:30:53 pm »
We might be able to help if you can tell us things like:
What limiter are you using?
Where did you place it in your chain?
What settings did you use?
What else was in your chain?
Any add'l info would be helpful...
J Lowes ยท OTR Mastering
Professional Audio Production for Life
www.ShoutLife.com/OTRMastering
nalbi
Re: Limiting HELP
« Reply #2 on: August 19, 2004, 05:56:12 pm »
OTR-jkl wrote on Thu, 19 August 2004 22:30
Ohhh My god thank you thank you..Smile
Now I start from here
In cubase export at   - 6 db
then in wavelab
first put in chain
Hi - pass  filter 20 hz or 30 to take some dB's
Multiband C4
and L2
May be I miss something in mixing process.... Confused
But I fabricate that chain
I didnt learn  anything about rulez
and principles about Mastering chains
Again I'm self-educated.....
Thanks again for attention
bblackwood
Re: Limiting HELP
« Reply #3 on: August 20, 2004, 07:49:17 am »
It goes a lot deeper than what it 'looks like' or even what you are doing (ie: arrangement dictates the energy levels through out the spectrum), so without hearing it, there's not real way to help out...
Brad Blackwood
euphonic masters
Ronny
Re: Limiting HELP
« Reply #4 on: August 22, 2004, 04:42:06 am »
nalbi wrote on Thu, 19 August 2004 15:27
Hello All!
about limiting
Candian Guitarist
CUT out peaks
-12 RMS or -11 rms
Your RMS on demo 1 is -9.25dB on the left and -9.37dB on the right, from my calculations.
Don't worry how the waveform looks, use your ears. Your peak is -.09 on the mp3. Using a 3 consecutive sample over setting you only have 10 possible samples clipping on L and 3 on R, these are possible clips not audible ones and par for the course on -09dB output when mp3'd. I zoomed into the hottest samples and can read most of each peak below the zero line. Even the mp3 encoding is not causing audible distortion, the samples move by too fast to be perceived as distortion and you don't have more than one of the 10 L and 3 R samples clipping, anywhere on the song at a time.
You know......
mastering....
What I must to do
Im Sorry for that
Dimitar Nalbatov
I'd check the accuracy of Wavelab, it shows the right side as being hotter when it's not, from my calculations, but hard to really know from your view angles which are way too compact. My suggestion is don't worry about the waveform. If you suspect clipping, zoom in to the clipped section and see how many samples hit above -0dB. You have the full view of the song in these Wavelab charts and the sides of your view pushed in to where the whole clip is only about 7 cm's wide. This may possibly be misleading you into thinking that there is clipping when there is none. People need to realize that editing by waveform is variably limited to pixel count and other display configuration factors, that are graphical and don't have anything to do with the audio itself.
As far as giving you compression starting points, which would boil down to preference, try this: Leave the C4 out of the chain and just L2 it. A/B it with the C4 on and off. If you can't get it to sound better with the C4 in the chain, leave it off. Don't think that you have to use multi-band compression everytime that you master, use your ears first and work on learning how to associate waveform view, with what's really happening with the audio. Different view angles wide/narrow/full-display-view/zoom-in/zoom-out, will all give you different impressions, if you don't setup the waveform view accurately.
