[quote title=Pricey wrote on Tue, 17 August 2004 16:24]
Bob Olhsson wrote on Tue, 17 August 2004 11:04 |
My opinion is that digital only sounds bad when it isn't linear ENOUGH!
Quote: |
I disagree.
I should have used clearer language. Digital is too linear, and too invariant, which makes it inadequate as an all-in-one solution. However, a DAW can be a useful complement to an analog system.
Pricey is very observant and very correct. Our very recording techniques have made analog tape a desirable medium. But first a word from our sponsor
What goes around, comes around. Does anyone remember an essay I wrote on this topic MANY years ago? Something about "good digital and bad digital" and "good analog and bad analog".
In summary:
The point is that if you go with a system that is supposed to be linear, like digital audio, you had better use the very best example of digital audio that you can, superior converters and the like, or its residual distortion will get to you. It will bother you DESPITE the fact that the distortion of digital recording is orders of magnitude lower than that of analog tape. Why? Well, because whatever residual distortion the digital system has left can sound very bad.
What I think Bob Olhsson means by saying "digital sounding bad when it isn't linear enough" is referrring to that "bad digital", e.g., systems with poor converters with poor monotonicity, idle tones, improper dithering, crosstalk from clocks to the audio, perhaps with some jitter thrown in, untransparent sound, low sample rate or poor filtering at any rate, etc. Anyone met up with a few converters or digital recorders of that ilk?
The point I made in that old article was that SUPERFICIALLY, digital audio is very linear, has flat frequency response, and all that. But how linear is it? In fact, it takes a lot of work to make digital audio VERY linear, with extremely low percentages of any of the above anomalies, or it will reveal itself to sound edgy, harsh, cold, OR just fuzzy and undefined and untransparent.
That's problem #1: Use good-digital; cheap converters don't cut the mustard.
Problem #2: Our mikes and our recording techniques are really not that great. Put a bright microphone in front of a trumpet and record to analog tape... the result is far more tolerable than with "accurate digital".
In an analog tape system, there are few such "edgy-making" mechanisms, and except for wow and flutter, our ears can tolerate and even LOVE the particular non-linear mechanisms that are there in the analog tape. Microphones which happen to be bright just sound prettier with the analog tape, whereas digital reveals their defects like a closeup on Mariah Carey's freckles.
Bottom line: The better the digital recorder you use, the less you will notice its defects, the more you will find its sound "analog like", even without the extra 3rd harmonic. Analog-like in the sense of "pure sound", as I am not referring here to the use of analog tape to soften and cover up other problems.
But alone, the "good" digital recorder may just sound too naked to you. For analog tape also helps to "gel" a mix... we often notice the analog tape playback sounding better than the recording! This is due to the tape's subtle compression and perhaps even printthrough, covering up the warts in the recording.
All of this, theoretically, CAN be simulated, and frankly, I find the major sonic purpose of the good simulators (like the HEDD), is to provide that subtle high frequency compression and 3rd harmonic that we like so well---not because that's accurate, but because it covers up a lot of evils.
Analog tape can make sound "wooly" or "muffled", by the way. But I'll take "wooly" or "muffled" over edgy any day of the week.
At this in my experience, I get great mixes on both formats, and I do not always "love the analog" version. Many mix engineers have lost the art of using the analog tape and when they do use it, they push it so hard that it sounds wooly and overcompressed. It's becoming harder and harder to find a mix engineer who can make a transparent, good-sounding analog tape.
