I'm a drumming engineer and PZMs are without doubt my favourite and most used mics of my collection of over 25 microphones ranging from switchable pattern large and small condensers, R-F-T dynamics and ribbons.
I have two tandy/radio shack pzms mounted on just one of the metal back plates, so, one diaphragm on each side like ears. Pull off the pop foam protectors too for a bit more clarity.
I use them for live recording to DAT/Minidisc and also room ambience and recently recorded my group's performance consisting of 4 people, percussion, cello/guitar effects, DJ and horn player playing in a circle in the Volkerschlagtdenkmal (an enormous shrine building in Leipzig, Germany with 14 second reverb!) to Mini Disc with spectacular results...The mics were on a stand in the center of the room and the 3D sound of the recording is remarkably clean and wide...all agreed it's the most 'you are there' sound we've ever heard.
For the ultimate REAL drum sound with great balance of all the kit elements, i place them about 1-3 feet in front of the bass drum in-line with the top of the bass drum hoop which gives a great fat kit sound with a great wide cymbal sound which is not too overly bright. The toms can sound a bit distant depending on the room but fat and rounded at the same time requiring very little work in the mix when a natural drum sound is needed.
Highly recommend this technique for the fat John Bohnam and sgt peppers drum sound. Put some slow attack, fast release compression at a ratio of around 3:1-5:1 for more fatness.
By the way, they can also sound great for spoken/sung voice and instruments like upright bass and even stuck on the sound board of instruments used live like dulcimer and accordian as they are very neutral sounding and have superb clarity and dynamics. They can be a bit noisy so check out the XLR modifications possible as they ARE balanced by their very sesign, you just need to hook them up correctly.
cheers!
p.s. Check out the album "Boomerang" from 'The Creatures' (former Siouxsie and the banshees singer and drummer Budgie)
as almost all the drums were recorded in a church to analog tape with a single PZM over the kit with just an additional bass drum mic for 'thump' emphasis. A truly great sounding percussion/drum album.
