I venture an opinion: neither your capsule is bad, nor are any of the high impedance resistors.
Usually, when there are complaints about a "weak" signal coming out of KM 8x, the source of frustration is either the current output strapping (set to 50 or 150 Ohms, with pad resistors engaged, rather than the 200 Ohms European standard) or a defective FET.
Considering that you mentioned more than one KM84 suffering from the same 'weak' output (you did not specify how much down, in dB, these are compared to other condenser mics), I lean towards a low-output strapping.
If that is the case (you would need to physically inspect your mics' insides), set them to 200 Ohms, and you will be fine.
Add on, after reading your response: good 3819 FETs are not easy to find. You can always use the types Neumann used, after they discontinued the 3819 FET in their mics: K105 or SK107.
