R/E/P > Bruno Putzeys (Designer) - Dave Hecht (Master Tech)
1000 Watt tube amp
<< < (5/6) > >>
Larrchild:
Slightly off-topic.. Great finally meeting you at AES!
Larrchild:
RMoore wrote on Tue, 30 March 2010 10:04
Apparently there is the possibility of arcing with these 813's if there is a failure mode..
He's running this thing at Max rated plate voltage and is totally asking for trouble. I never ran 813's above 2250 vdc.
John Monforte:
At 2500 volts, won't it generate x-rays?
Larrchild:
Hence the term "more transparent".
Seriously, just barely.
> 10kV they become an issue.
Moby (Mike Diack):
Sometimes 2 output tubes is enough.
Here is a Mullard design using MZ2-200 bottles (sorta like a 212 with a bowler hat)
http://www.r-type.org/static/mz2200.htm
And a locally made version of it that I inherited
(Used to power dozens of Vitavox horns at religious rallies in the '60s). 58 on stand is for scale.
M
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
