Bob -
See if you can follow this:
Current chain:
- 1st instance of Samp used for playback of original file and for any processing done In-the-Box (EQ, Comp, etc.) <Playback is at project sample freq/bit depth>
- Dig out of soundcard into tube unit (to add analog flavor)
- Dig out of tube unit back into soundcard
- 2nd instance of Samp used to capture incoming processed audio at project sample freq/32-float (pre-limiting/pre-dither)
- Limiting and dither are applied in the 2nd instance of Samp
Here's the key:
Samp has a Live Input function that allows me to capture an incoming audio signal on the HD while simultaneously applying FX on the incoming channel. Because of this, I can apply the s/w limiter on the channel that is armed to record (or apply the limiter across a buss that the channel is routed to...) and the signal gets processed (limited) on the way to the HD. This set-up allows me to hear all processing working together (just as if it were all being done on outboard gear and I were monitoring the output of the "capture" DAW.
When I get everything set the way I want it, I turn Samp's real-time Mixdown fundtion On and play the source file. Source file gets processed thru the chain and captured on the HD as a finished file.
In using this method though, I still have to deal with the SRC (when applicable). With my current gear, there's only 3 ways I can do it:
- On the way into the "capture" (2nd) instance of Samp which is not a very good real-time SRC
- At the end of the process (post processed/dithered/captured) off the HD using offline Samp SRC or other like R8Brain.
- Pre any processing (first thing - and probably the worst scenario...?)
There is one other possibility:
I could send the signal Dig out of the playback instance of Samp into another piece of gear (like my Tascam CD-RW2000) and use it to do the D/A, then send it to the analog input of the tube unit , then dig out of the tube unit and on to the soundcard dig input into the 2nd instance of Samp capturing at 44/32. I think it would work but I'm leery of using the D/A convertors in the CD-RW.
Normally I don't have to worry about all this as the source files are mostly 44/24. But, as was the case last week, I need to come up with the best way to do the SRC (until I can get an outboard unit).
I hope I explained this clearly enough to be understood...
