Author Topic: Monitors for Motif in Studio  (Read 3259 times)
jc-muscleshoals
« on: February 16, 2010, 06:15:49 pm »
I want some full range powered speakers/monitors for my Motif in the studio. If an artist wants to play piano and doesn't want to wear headphones, I am limited to my Dynaudios or NS10's. I don't want to blow my monitors, plus you can't get enough bass out of them. What do you guys recommend? I was thinking a subwoofer with a pair of cheap monitors like Behringers or larger woofer monitors.
"My mind is a raging torrent, flooded with rivulets of thought, cascading into a waterfall of creative alternatives".
hargerst
Re: Monitors for Motif in Studio
« Reply #1 on: February 16, 2010, 08:08:26 pm »
If you're not too concerned about acoustic sound quality (because you'll be taking a line out from the piano for the recording), why not search Craigslist for a cheap, powered, small PA cabinet?
Harvey "Is that the right note?" Gerst
Indian Trail Recording Studio
TheDan
« Reply #2 on: February 18, 2010, 01:04:36 pm »
JBL Eons are usually only a couple hundred dollars, and are perfect for this sort of thing.
It's all a ride.
John Ivan
« Reply #3 on: March 08, 2010, 06:03:12 pm »
As it turns out, I really like my M-AUDIO BX8a boxes. When I first brought them in, I was not at all sure about them. I was so used to my AMR 3 ways, and then I used old JBL,s for loud tracking/demo mixing when I first got to this room..
The BX8's image great [the sweet spot is huge for instance},, they don't change drastically when I move my chair in and out, side to side and so on.. At first, I thought the bottom end was to loud.. NO! It turns out that I finally have monitors that allow me to nail the bottom right off the bat. I also though there was a bit of a hole in them around 1-k.. Again, I have a different idea about them now. Other monitors seem to rip my head of in the mid range now.
I mixed on the AMR's for many many years so I was bummed when they were ruined in an attempted robbery. {I still might fix them, but can I mix on them now?}
I like these M-AUDIO boxes way better than the Mack's a lot of guys have.. The fact that I didn't like them at first but now find my mixes translate better and I can hear things I couldn't before {at least not as well} tell me I made a wise choice here.. Oh, you can play rockin' piano through them all day and not hurt them. I do this a lot ;-}.. Check them out. I dig them..
Ivan..........
"Transformation is no easy trick: It's what art promises and usually doesn't deliver." Garrison Keillor
Ian Visible
« Reply #4 on: March 11, 2010, 01:01:16 pm »
Do you find the BX8s err on the bright side?
I find they make me mix a bit dull/dark sounding...ought to tinker with the little switch thingies on the back to reign in the high end a bit I suppose.
Just wondered if it's just me?
John Ivan
« Reply #5 on: March 11, 2010, 06:13:42 pm »
Ian Visible wrote on Thu, 11 March 2010 13:01
Hi Josh,
No I haven't found them to be to bright, {there by rendering my mixes dull},.. My AMR's were pretty bright though, in a really great way. Man, I could always nail things like Vocal level and so on.. The mid range was just so great..
I don't have switches on the back of mine for changing the response. On/Off, and a level control is all I have. These are the older ones.. I love them.. They seem to make me work at things that seemed to come more easily with the AMR's. On the other hand, things that I had to work at before, come together very quickly.. Like, the bottom is nailed down very dependably with these..They don't seem peaky down there. They seem right..
Ivan..........
