April 24, 2024, 07:02:42 AM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
R/E/P
R/E/P Archives
j. hall
mastering levels
« previous
next »
Pages:
1
2
All
Go Down
Print
Author
Topic: mastering levels (Read 5445 times)
0dbfs
Sr. Member
Offline
Re: mastering levels
Reply #15 on:
January 29, 2010, 02:21:26 PM »
KB_S1 wrote on Thu, 28 January 2010 05:56
If you really have to do this and you are running PT HD, this would be my method.
Save each session as a new version:
Put all audio and Aux tracks routed to MIX into a group>
Put track view into Volume Trim
Use trim tool to bring the level down by 1 or 2db.
This will bring everything down by the same amount relative to original fader positions throughout mix.
The same could be done with a VCA group I think, need to check.
I would set up this way with the original source tracks to keep levels in check throughout the mix and try to keep the aux's at unity. Just double-check any parallel or bus processing for input/threshold level changes that would change the amount of compression.
Best,
j
Jonathan Burtner
Music is Everything!
Audio is Everything Else!
j.hall
Hero Member
Offline
Reply #16 on:
February 01, 2010, 11:58:13 AM »
that seems too risky to me. you'll have a much harder time matching your compression gain staging.
j.hall
Theta Rhythm
Facebook
Print
Pages:
1
2
All
Go Up
« previous
next »
R/E/P
R/E/P Archives
j. hall
mastering levels
