Author Topic: XPATCH from SSL  (Read 2064 times)
Thomas W. Bethel
XPATCH from SSL
« on: January 18, 2010, 09:43:02 am »
-TOM-
Thomas W. Bethel
Managing Director
Acoustik Musik, Ltd.
Room With a View Productions
http://www.acoustikmusik.com/
Doing what you love is freedom.
Loving what you do is happiness.
Tim Halligan
Re: XPATCH from SSL
« Reply #1 on: January 18, 2010, 09:58:27 am »
Looks like a more up-to-date version of the old Tantek Master Matrix...if some of you old guys remember that one. Very Happy
That was a good idea...unfortunately it massacred your sound.  Confused
Cheers,
Tim
"Don't forget, we are all engaged in a battle to the death against mediocrity." - J. Whynot
"You can tune a room only with a bulldozer." - Andy Peters
compasspnt
Re: XPATCH from SSL
« Reply #2 on: January 18, 2010, 12:34:20 pm »
No we can finally master through guitar pedals...
Darius van H
Re: XPATCH from SSL
« Reply #3 on: January 18, 2010, 04:35:39 pm »
hmmmm, 700 squid, compared to about 5000 for the Crookwood. I wonder where the saving has been made. I guess SSL would expect to shift a lotmore units then Crookwood, so that partly explains the price difference. Plus Crookwood has a remote.
dietrich
Re: XPATCH from SSL
« Reply #4 on: January 19, 2010, 08:51:47 am »
Seems very useful and at a decent price.
Crispin HT
Re: XPATCH from SSL
« Reply #5 on: January 19, 2010, 11:03:32 am »
Just a few observations for you on this.
The Xpatch is intended for a recording environment, so it uses electronic buffering and switching, and is a mono 16x16 matrix.
I don't know if they switch balanced, but they probably have op amp buffers on the inputs and outputs then route unbalanced in between.  Electronic switches nowadays are quite good, but they're not in the same calibre as relays.
Cost wise a 16:1 electronic switch comes in a small SMT package and costs about $1 in qty, and the equivalent 16 relays cost about $20 and take about 100cm sq of board space plus lots of power.
A 16x16 mono matrix for mastering isn't much use, as you'd want a stereo matrix.  You can reconfigure the 16x16 to be a stereo 8x8, but you'd need to switch each channel separately.
Our 8x8 stereo relay switcher, with no frills costs about
Cheers,
Crispin HT
Crookwood
http://crookwood.com
Schallfeldnebel
Re: XPATCH from SSL
« Reply #6 on: January 21, 2010, 10:45:55 am »
Bill Mueller:"Only very recently, has the availability of cheap consumer based gear popularized the concept of a rank amateur as an audio engineer. Unfortunately, this has also degraded the reputation of the audio engineer to the lowest level in its history. A sad thing indeed for those of us professionals."
