Hey Jason, Chuck alerted me to your under taking and there's some good advice passed onto you so far. There's some stuff I'd like to add and detract.
The fm's are fine as are the bc/vishay aml 138 (the tan plastic encased versions). They ALL need to be 105c. Check your diameters though, it's tight in there. Be sure to get the correct axial/radial positions. These are know to work and last...
Find a module(if any) that can be a bench mark for the first (2) your going to tackle.
A quick mod you can do to all 11491 eq boards is jumper pin one to pin eight on conn #3. This gives the eq the correct ground reference and takes the eq out of circuit. Stock, the eq is always hanging off of the channel (soft switched in or not). Ughh.
I would recap the audio path ONLY to start. The (2) sandwiched boards (11491 &11492) both need it. You'll also be taking care of the insert path at the same time. Be careful unscrewing them. The stand offs only want to be unscrewed from one side. If yo decide to pull the eq to do the caps, take care to NOT break the (3) connectors attached to the motherboard. They're a bitch to get out. If you leave the eq in the module, again be careful to NOT over flex the connectors.
Depending on the age of the console, how well it was wave soldered and the amount of recaps, take EXTREME care to NOT pull up solder lands. There have been consoles I've done where it was actually easiest to heat the cap lead and lift it with a small screw driver, then reflow the joint, then suck it out. PIA. Hopefully you have relatively clean/non cold joints and the Hakko will work like a charm.
There's 20 something caps to change, if you scan the shem, I can show you the ones to replace. Most likely, the power bypass caps don't need it unless your dist is into the .01%'s. After pulling the caps, clean the hell out of the solder lands and it's surrounding area. The impedances running around in there, are very high and you can get stray s**t that messes with logic functions. Do the same after replacement.
Tantalum caps, believe it or not, have a tendency to add MORE grain to the eq on the VR, the opposite of what your trying to accomplish. Been there...
There are opamps THAT CAN NOT BE SWAPPED in the VR. IT WILL OSC.... On the 11491 card, do not change IC3,IC4 or IC6. Known opamps that work (and sound better) in the eq are the BB/TI opa138 & the BB/TI opa 2138. Don't blindly start swapping chips as others have recommended. You'll be sending out signals to aliens and Michelle Bachman.
Get your eq's back to spec and then you should deal with the mic/line card(plenty of mods for that one) on the (2) first modules so you have a clean pair to reference.
The eq boards are childs play. Wait until you get to the mini-fader board. LOL.
Ronzie
