Well, I've tried to maximize the available space as much as possible by squeezing the hall to a the minimum.
The result can be seen here:
The thing is: I really, really need SOME space in the hallway since the doo is going to the outside, so it will be a place to get wet coats off and such... Plus, I will also have the electrical fuse box (or how is this correctly called in English) over there.
And last but not least, I also need to be able to access the airco units filter for cleaning from there.
So, taking these things in consideration, the plan above is what I truly believe to be using the maximum foorprint while still fullfiling the requirements described above. However, one major drawback is that I can only fit ONE door then, so no double wall isolation there. A second door would simply not open fully... So I was wondering whether this could still be a valid option???
Anyway, starting from there, I already tried to get an idea of how the acoustical treatment could look like. The intermediate result looks like this:
The Good: it's a lot bigger, there is more room for bass-trapping (especially in the back), it has almost perfect symmetry (the back might never get perfect due to the piano and such...).
The Bad: I still have a problem opening up the leftmost window. But maybe that doesn't need to be a problem at all.
And th elack of perfect symmertry in the back, of course.
Here's is a picture showing the speakers and piano as well:
Anyway. I would be very glad with any input from you guys now. Am I on the right track or still far from it? What still terribly wrong, etc... Maybe let's concentrate on the Soundproofing first, since that's the one being built now...
Many thanks.
Regards,
Bert
