adamjknight wrote on Thu, 19 November 2009 17:31 |
Hi Guys,
Maybe i don't deserve it but i now have the A2D!
I am trying to connect it to my MBox2 via SPDIF which is all fine. I have gone into protools set up and specified the A2D as an external clock.
I go to a track and select SPDIF (Left) and though the APIA2D is picking up sound...i don't appear to hear anything from my headphones plugged in to my MBox2?
What haven't i connected? What am i missing?
Cheers, Adam
In your ProTools I/O Setups, is your optical input (not sure if MBox2 has one) set for S/PDIF or ADAT? If it's set for S/PDIF, you might actually have set your track to input from optical, though you're hooked up via coax (or vice-versa). Also, "S/PDIF Left" is a name given in the I/O setup screen, and could actually be hooked to any input. Make sure that it is actually assigned to the S/PDIF inputs.
Some obvious stuff that may have been overlooked:
- Mic is plugged into the correct channel on the pre (1, I assume)?
- Track is record-enabled?
- Track fader is up, mutes and solos disengaged?
- Track output is correctly assigned?
- Does the A2D need to have its digital output enabled?
- MBox 2, I believe, has a max sample rate of 48 kHz. Is your A2D set for the same sample rate as the session?
- Your S/PDIF cable is good?
- Are you sure PT is properly clocked? Do you get bursts of noise on the track instead of audio? This indicates clocks out of sync.
