dirkb wrote on Thu, 22 July 2004 16:52 |
Just to give some more insight, it's actually phase issues that I'm worried about. Adding some 3-4dB to the drums, leadvocal and ac. guitar in the top end, get's me quite in the ballpark. I just like the sound of especially the drums and leadvocal un-eq-ed and adding high-end takes away a little of the magic, but perhaps I'm just being too sensitive here.
dirk I'm not sure there is a "too sensitive" place for mixing or mastering, not when the sensitivity tells you about musical magic's presence or absence. phase issues will kill the source's realness for sure.
so what i hear you saying is that either your tracking was darker than you'd have liked, or your recording chain is darker than you like.
i also hear you saying that the phase issues are giving you want you want but taking away something you want/giving you something you don't want.
this may be a case for leaving SOME of it for mastering ... IF:
you make it with a 'full range of tones' that are simply not in the right part of the spectrum.
as an example, i did a mastering job for a guy that eq'd nothing post tracking ... NOTHING. and very little eq at tracking.
so the record was dark, very dark ... but it mastered up like you would not believe, and it became what he wanted, consistent with his mix, but not at all like his mix ... brighter, tighter and still full range.
in his case i had no idea he used no eq in mixing until after wards, and then it all made sense.
his chain was:
source - mic - focusrite all in one pre/eq/comp - DP - ITB - bright monitors with little low mids
so again, know your chain ... and maybe know the chain of what you really like to hear (your comp CDs)
the whole point of all the gear talk is to get the boxes that give you those sounds you want with little effort. if you have to brighten up everything, your chain needs some adjustment ... and until then mastering can help.
after you have mics and pres and a mixing system that gets you close with the right choices and little compensation, mastering will make you sound like a genius
