The answer depends on the capacitance of the cable as well as the output impedance of the microphone. For their microphones with output transformers, Neumann has specified for decades a maximum cable length of 300 meters--and that's with the output transformer in the standard 150 or 200 Ohm setting. To avoid the loading effect of long cables it is far better if the output transformer is set at its lowest-impedance setting--generally 50 Ohms--and if the cable doesn't have unduly high capacitance between its modulation leads. (Some well-known Japanese star-quad cable falls into that category, unfortunately.)
Transformerless microphones can have even lower output impedances, and usually the character of that impedance is primarily resistive within the audio range. Thus even the 300-meter limit doesn't apply to them unless cable with extremely high capacitance is being used. But this forum isn't exactly teeming with fans of transformerless microphones, so I'll simply quote from Neumann's manuals for their fet 80 microphones, most of which contain either this exact text or something very much like it: "The cable length between microphone and amplifier should not exceed 300 m (980 ft.). The capacitance of greater cable lengths could affect the frequency response and, in conjunction with the leakage inductance of the microphone's output transformer, would result in a rise at the upper end of the frequency range."
--best regards
