R/E/P > j. hall
PT Easter-Eggs, and other usefull unpublished info...
maarvold:
Podgorny wrote on Fri, 11 September 2009 20:43
activating, in-active plugs/inputs/outputs
ctrl + option + ⌘ + Click.
Once on each insert slot needed for both mono and stereo tracks.
Shouldn't take more than ten seconds.
Activating, in-active plugs/inputs/outputs on highlighted tracks as a group:
shift + ctrl + option + ⌘ + Click.
Once on each insert/input/output slot needed for both mono and stereo tracks.
wwittman:
assign any track to multiple outputs (a largely 'secret' function) - hold CONTROL and select the additional output or bus... you'll see a + appear next to the selection to tell you that multiple outputs are in effect
grantis:
Recently discovered this handy "hotkey" or "quick-key".
"B" is the same function as ⌘ + E (separate region)
jetbase:
wwittman wrote on Wed, 16 September 2009 13:50
That's awesome! You're a lifesaver. At first I couldn't get it to work, since I'm on a PC, but after a while I worked out that the PC equivalent is Start then select the output. Cheers.
marcel:
Anybody know a 'Create New Playlist on Selected Track(s)', or 'Create Duplicate Playlist...' shortcut? I'd love to figure that out. I playlist vocal OD takes and sometimes the dropdown of playlists gets (ahem) very large. Not a situation where you want to spend time scrolling down...
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
