Author Topic: Sound barrier material?  (Read 1793 times)
Rich Mays
« on: August 02, 2009, 06:24:53 pm »
I recall seeing a spec on material that acts as a sound blocker-- perhaps an Owens Corning product-- that I will need to put in between drywall and the wall behind it.
Can anyone help here?
Rich
Sonare Recordings
www.sonarerecordings.com
crna59
Re: Sound barrier material?
« Reply #1 on: August 02, 2009, 08:29:30 pm »
ASC makes dampening squares and sheets of material to hang behind drywall.
We used Green Glue between drywall and hung the drywall on ASC dRSC. Works perfectly!
Regards,
Puget Sound Studios
Bruce A. Brown
Mastering & Post Production
Seattle, WA
It is easier to ask for forgiveness than to ask for permission! Buy! Buy buy....
franman
« Reply #2 on: August 15, 2009, 11:59:48 pm »
My 10 cents: Just put up another layer of drywall... when properly installed this will provide a higher stc and be a lot cheaper than the barrier materials. There are good ways to use these materials, but sandwiched inbetween drywall is not the best application. At that point, it's not a 'limp barrier' and it's mass at 1lb/SF is not as significant as another layer of drywall at approx 2.5lbs/ SF..
my 10 cents.
FM
fmdesign.com
griffinaudiousa.com
rankus
« Reply #3 on: August 17, 2009, 10:59:44 pm »
franman wrote on Sat, 15 August 2009 20:59
my 10 cents.
FM
Worth every penny  Smile
Podgorny
« Reply #4 on: August 17, 2009, 11:59:28 pm »
With regards to adding a second layer of subfloor in residential construction, is Green Glue the best choice, or would it be better to have a layer of compressed insulation between the two?
"Nobody cares what the impedance is; all they care about is when you can walk into the room, set up a mic, turn the knobs, hit record, and make everybody go 'wow.'"
