Pages: 1 2 3 [4] 5 6 ... 10   Go Down
Author Topic: Any DIY EQ interest?  (Read 52243 times)
bblackwood
Re: Any DIY EQ interest?
« Reply #45 on: July 27, 2004, 07:18:00 PM »
OK, I'm starting to like DC's three band Baxandall (with either IC or 990 size opamps) idea. I dunno, probably just as easy to implement, especially with PCBs (which we will have made - already have a great source).
Thoughts?
Brad Blackwood
euphonic masters
theo mack
« Reply #46 on: July 27, 2004, 09:55:28 PM »
I'm In !
990 size opps please.
How about a face plate order too.
theo mack
Freelance Audio Guy
Las Vegas, NV.
moogus
« Reply #47 on: July 28, 2004, 05:43:59 AM »
Terry Demol wrote on Mon, 26 July 2004 19:37
Hi Moogus,
Is this with the JLM99V or as your instrument opamp description
suggests, a fully balanced instrumentation amplifier Bal IP ->
SE OP, or just the front end of an instrumentation amp ie;
CM gain = x1 bal in bal out, or lastly, a fully balanced VG
(current) IP such as Nelson Pass's "Supersymmetry"?
Cheers,
Terry
Hi Terry
The inst. amp I speak of is not the 99V.  Its the one Joe designed for the mastering console and it has balanced input and output and an unbalanced 'insert' point in between.  We dont sell it as a sepperate 'product' at the moment, as it was really just made for the console, but were working on a new pure 990 style opamp called the 99S (S for symetrical).
M
This supports my pet theory that weird, purple jellyfish are behind everything peculiar that ever happens anywhere.
jfrigo
« Reply #48 on: July 28, 2004, 02:52:26 PM »
bblackwood wrote on Tue, 27 July 2004 16:18
Thoughts?
Forgive a non-designer's question, but I thought the Baxandall circuit was a shelving filter, and three shelves would be a bit odd. Is there a peaking filter that is close enough in circuit design to still be called Baxandall? As I just use the things and don't design them, I'm in the dark here. Who can help?
I'd think three broad peaking filters would be preferable for this particular project, but I guess two shelves and a mid peak would be OK too. This is starting to get interesting, so maybe I'll hop on board for this project. 990 size seems like a good idea as I'm interested in trying some Forssells in there.
bblackwood
« Reply #49 on: July 28, 2004, 03:04:51 PM »
jfrigo wrote on Wed, 28 July 2004 13:52
His original designs were shelves, but seems like just about anything that has the filters in the negative feedback loop is considered a Baxandall anymore...
Brad Blackwood
euphonic masters
Terry Demol
« Reply #50 on: July 28, 2004, 11:19:00 PM »
jfrigo wrote on Wed, 28 July 2004 19:52
Thoughts?
Yes, there are 3 band Banxandall peaking EQ circuits
that work in NF loop of an inverting OPA.
I'll dig one up and send a link tonight.
My guess a FET IP might be better than BJT. You can keep
R's high and C's low and use HQ film types also no offset
problems so can be direct coupled. Should be nice.
Also a thought, you might want to include a mid
shift switch, which should be pretty easy to
do.
Cheers,
Terry
Bob Olhsson
« Reply #51 on: July 29, 2004, 10:07:43 AM »
My understanding has always been that a Baxandall eq. uses very broad peaks set up so that the first frequency affected moves closer to the midrange as you increase the amount of boost or cut.
bblackwood
« Reply #52 on: July 31, 2004, 09:58:01 AM »
Only 10 votes? Come on, weigh in with what you'd prefer...
Brad Blackwood
euphonic masters
theo mack
« Reply #53 on: August 01, 2004, 03:50:55 AM »
hey are we doing a stereo unit?
I'd like stereo. Shared psw, and controls.
theo mack
Freelance Audio Guy
Las Vegas, NV.
bblackwood
« Reply #54 on: August 01, 2004, 07:57:45 AM »
Stereo, yes.
Brad Blackwood
euphonic masters
JPRisus
« Reply #55 on: August 01, 2004, 09:07:40 PM »
what about stereo/dual mono? i'd like two independent sets of controls personally.
J.P. Sheganoski
Engineer/Mixer
www.RisusProductions.com
Purevolume.com/risusproductions
bblackwood
« Reply #56 on: August 01, 2004, 11:15:53 PM »
That's what I meant, JP (sorry if I didn't make it clear). Two mono channels in one box...
Brad Blackwood
euphonic masters
Kris
« Reply #57 on: August 04, 2004, 11:37:10 AM »
You can put me down for 'either'... or 'both' . Very Happy
Techne
« Reply #58 on: August 04, 2004, 02:10:52 PM »
My question may be a bit premature for this project, but i was wondering what opinions you DIY'ers have about chassis selection.  Anyone have good/bad experience with any of the prefab boxes out there?  Sorry if this is a bit OT.
JPRisus
« Reply #59 on: August 04, 2004, 02:36:44 PM »
Techne wrote on Wed, 04 August 2004 14:10
Just got a Hammond half-rack enclosure for my monitoring unit... seems like a solid piece, although i haven't drilled into it yet. I've used small Hammond enclosures for homemade guitar pedals in the past, good stuff, never a problem. Hope the same for the rack units!
J.P. Sheganoski
Engineer/Mixer
Pages: 1 2 3 [4] 5 6 ... 10   Go Up
Page created in 0.076 seconds with 20 queries.
