Author Topic: Optimal RT60 for a mastering room?  (Read 17514 times)
antonio
« on: May 08, 2009, 06:56:57 am »
Hi all,
according to you which is the optimal reverberation time for a mastering room?
For recording studios and surround sound listening rooms there are suggestion like the one reported in the fig.1
My I think that  according to this suggestion that RT60 for a mastering room  shold be between 0,2 - 0,4 seconds?
Or I should think that mastering room should be more close to the acoustic of a domestic  rooms so according  to the fig. 2 it must be higher,  let’s say between 0,4 – 0,6 seconds?
index.php/fa/12154/0/
Ethan Winer
Re: Optimal RT60 for a mastering room?
« Reply #1 on: May 08, 2009, 02:58:25 pm »
I'm sure others will chime in, but in my opinion RT60 is not a useful spec for domestic size rooms. Small furnished rooms don't really have true reverberation. Rather, it's a series of reflections that decay over time. The typical goal is to use absorption to get all early reflections to -15 dB or more below the direct signal from the speakers. In this case "early" is defined as reflections arriving within 20 milliseconds of the direct sound.
--Ethan
antonio
« Reply #2 on: May 08, 2009, 03:46:48 pm »
Hi Ethan, you highlight  an interesting point. But even if the domestic rooms may not have a perfect exponential decay they  sound more “alive” , from a reverberation point of view, than a control room in a recording studio.
In any case, I think that, as much as exist a suggested RT60 for control rooms should be a suggested RT60 for mastering rooms
Thomas Jouanjean
« Reply #3 on: May 08, 2009, 04:15:58 pm »
Most Mastering engineers I've worked with wanted a very analytical environment. It usually resulted in rooms on the dead side, with very tight bass and slightly 'enhanced' stereo image.
IMHO, I'd say Mastering rooms, while still needing to be balanced, are usually very controlled environments in which the engineer can make quick decisions without ever doubting what he hears.
My CRs usually have a higher RT than the Mastering rooms and this is not an arbitrary decision I took, it's the result of what is asked by the clients.
Thomas Jouanjean
Pro Audio Partners:
ATC Loudspeakers
FOCAL Professional Speakers
antonio
« Reply #4 on: May 08, 2009, 04:32:08 pm »
Thomas Jouanjean wrote on Fri, 08 May 2009 15:15
ok, but in terms of numbers? 0,2 s 0,4 s or what?
And, from your point of view, which is an optimal value?
Thomas Jouanjean
« Reply #5 on: May 08, 2009, 04:56:18 pm »
antonio wrote on Fri, 08 May 2009 15:32
The optimal value varies with the room (volume, etc) - there's no particular recipe. The .4/.2 is a good benchmark though.
You should make sure the reverb is as diffused as it can be and that the decay is linear and homogenous (as little variations as possible between octaves).
Not surprisingly, this comes 'naturally' if the room is well designed. (read: RT is not in my top priorities when designing)
Thomas Jouanjean
Pro Audio Partners:
ATC Loudspeakers
antonio
« Reply #6 on: May 08, 2009, 07:18:00 pm »
Thomas Jouanjean wrote on Fri, 08 May 2009 15:56
Yes ok , but anyway you must consider it so it’s better if you have a target. If you don’t have a particular target o recipe haw you decide which type and how much absorbing material you put in a room? This affect your RT60? right?
I was assuming that this a necessary condition.  So my question comes after this condition.
The optimal value varies with the room (volume, etc).
Yes  in fact  if we consider de above mentioned formula of the figure 1 : tm=0,25 + (V/Vo) 1/3
It’s  clear that that tm changes with the volume. Sorry if I insist but my question was simple : RT 60 more close to a control room  or to a living room? And if it’s more close to a control room or a living room we should quantify this value otherwise it’s just an useless discussion
franman
« Reply #7 on: May 09, 2009, 01:12:01 am »
Gotta chime in on this one. I don't feel that there is a statistical RT time in small listening rooms. It can't be reliably measured, although you may choose to calculate it.
I agree with Thomas, that all mastering rooms we've done are on the dead side... very short (.2 - .4 if calculated) and I tend to shoot in the same range for control rooms as well.
I also agree with Ethan, that the 'field' in these smaller rooms is really about a proper distribution of reflections and CONTROL of early reflections (shorter than the haas effect).... you really need to avoid early reflection back to the listening position shorter than 19-22msec (open for discussion) and louder the -15 compared to direct signal (also open for discussion)...
These are things we typically measure in the ETC function of the TEF... there is no repeatable RT in these smaller rooms, although you can measure a repeatable RT in a typical living room... tends to more like .5 - .8 depending on volume...
my 10 cents....control early reflections, and make a diffuse return after the haas effect.... this is what RFZ design is all about.
fmdesign.com
griffinaudiousa.com
Thomas Jouanjean
« Reply #8 on: May 09, 2009, 06:38:08 am »
Francis summed it all very well...
antonio wrote on Fri, 08 May 2009 18:18
Of course I will check it all out and measure, but it never is a surprise.
What I mean is that once I got the geometry / RFZ / Broadband + LF management, the room is already within the RT 'target'. It's low and well within the .4/.2 benchmark. If it's not then I missed something. Controlled LF implies low RT. Then Diffusion will balance the room properly and even out what (and if it) needs to be.
All designers have *RT* in mind when working - but it's not a variable on it's own, it's one variable that is dependent on other. And Ethan makes a good point in his post about RT.
The trend here is obviously close to a CR. Now to quantify this value with a strict number like .3/.15 would IMHO be strange. It will vary with every project. And it's also a question of taste - which cannot be quantified. The broad benchmark of .4/.2 is a good reference point, but that's it. If the client wants a RT higher than .2 in the higher freq range I will do just that. But also warn him...
Thomas Jouanjean
Pro Audio Partners:
ATC Loudspeakers
antonio
« Reply #9 on: May 09, 2009, 07:44:01 am »
Francis, Thomas, Ethan thanks for your for sharing your knowledge
franman wrote on Sat, 09 May 2009 00:12
Francis  this are very interesting point of discussion especially if it’s possible to connect this numbers to what happens from a listening point of view.
Ethan Winer
« Reply #10 on: May 09, 2009, 03:39:05 pm »
franman wrote on Sat, 09 May 2009 01:12
you really need to avoid early reflection back to the listening position shorter than 19-22msec (open for discussion) and louder the -15 compared to direct signal.
Of course I agree with that, but it brings up a related question for you:
You're probably aware of Floyd Toole of Harmon fame, and his new audio book where he says leaving early reflections intact sounds "better" than absorbing (or diffusing) them. I've never had that experience, not once, not ever. Yet more and more I see people parroting Toole and arguing that early reflection are good and absorbing them is bad.
What the hell is up with that?
--Ethan
avare
« Reply #11 on: May 11, 2009, 01:38:47 pm »
Ethan Winer wrote on Sat, 09 May 2009 15:39
Toole is writing about what sounds pleasing.  We (professional monitoring) are interested in what is accurate.
Andre
Greg Reierson
« Reply #12 on: May 11, 2009, 01:48:17 pm »
Dave Moulton is into early lateral reflections as well. He's a sharp guy but this seems strange to everyone I've talked to.
http://www.moultonlabs.com/more/nick_batzdorf_interview/
GR
Ethan Winer
« Reply #13 on: May 11, 2009, 03:05:21 pm »
avare wrote on Mon, 11 May 2009 13:38
It sure does not sound "pleasing" to my ears! Stop me if I already told this story: Laughing
After having absorbers at the side-wall and ceiling reflection points in my 5.1 living room setup for a few years, I replaced them once with diffusors as an experiment. My wife and I sat down to watch a concert DVD, and in less than five seconds she said "Much worse!" and I had to agree. Now, maybe in a room 30 feet wide, bare walls or diffusion are okay. But not in any of the smaller rooms I usually deal with.
--Ethan
Ethan Winer
« Reply #14 on: May 11, 2009, 03:13:45 pm »
Greg Reierson wrote on Mon, 11 May 2009 13:48
It seems strange to me too, and I can offer a bit more. The last time this came up (only a few months ago) in another forum, Bob Ohlsson said the same thing. So I arranged to visit Dave Moulton at his home and drove the three hours each way to hear his setup. It was the strangest sounding system I ever heard. Dave has B&O BeoLab speakers in a largish room with only a tiny amount of acoustic treatment on the front wall. Imaging was non-existent, and everything sounded like it was floating in the air four feet above the speakers. There was so much ambience on the music I wanted to ask Dave if he accidentally had his 5.1 processor set to one of those "large hall" type presets, but I didn't want to embarrass either of us so I didn't ask. Laughing
--Ethan
