Author Topic: Mass/Isolation/Frequency transfer data  (Read 5024 times)
Sigert
« on: March 17, 2009, 12:02:13 pm »
Is there data available describing correlation between mass, isolation and frequency? Or is this the sort of data people pay for?
Was that my cue?
Ethan Winer
Re: Mass/Isolation/Frequency transfer data
« Reply #1 on: March 17, 2009, 03:15:27 pm »
There's a ton of info here, and elsewhere on the same site:
 http://www.greengluecompany.com/understandingSoundproofing.p hp
--Ethan
Sigert
« Reply #2 on: March 17, 2009, 04:45:06 pm »
That's very nice info Ethan, thanks. It confirmed what I'd already gathered so far: STC is not an appropriate qualification when dealing with (live) music.
I'm still without an answer to my question though.
Given a space devided in two by a single leaf wall with infinite length and width. If I put a rockband on one side producing 115dB of rock 'n roll noise (with equal energy in all octaves), and a grown person (with no abnormal hearing loss) on the other side, how many Kg/m
Was that my cue?
Thomas Jouanjean
« Reply #3 on: March 17, 2009, 05:36:28 pm »
Maybe time to enrole in a proper engineering course Sigert...  Rolling Eyes
To put you in the right direction:
- What happens when I double the mass?
- What about rigidity?
- Snell-Descartes law... since we are in a random incidence in your case.
3 more related tips:
index.php/fa/11700/0/
Thomas Jouanjean
Pro Audio Partners:
ATC Loudspeakers
FOCAL Professional Speakers
Sigert
« Reply #4 on: March 17, 2009, 06:39:06 pm »
Thanks Tomas. That should keep me busy (read: quiet) for a bit. Time to crunch some numbers. Munch munch Smile
Was that my cue?
Sigert
« Reply #5 on: March 17, 2009, 08:59:37 pm »
Z = impedance
m = mass
theta = angle of incidence (relative to normal incidence)
c = speed of sound in air
D = Angular momentum?? (whatever it may be)
EDIT: Is this the target frequency, but converted to radians?
w = Angular frequency?? (also at this point, still a mystery to me)
Was that my cue?
andrebrito
« Reply #6 on: March 22, 2009, 09:06:24 am »
There are several models to calculate these, some are a really pain in the ass taking into account flanking transmissions.
But I would say you would have to be crazy or immensely rich to want to have a rock band rehearsal space near a space someone living particularly at night.
Noise disturbance laws are VERY strict.
BTW
w = 2 * pi * f
Acoustician and Musician
http://www.onlineacoustics.com - Projects and Products (RGP and Green Glue)
http://www.sonicflames.com - my crazy label
Sigert
« Reply #7 on: March 27, 2009, 09:59:24 pm »
If I understand things correctly, adding more mass to a boundary will lower its resonance frequency AND increase its resistance to excitation.
Rigidity seems to be the resistance of an object to being deformed under stress. Rigidity is not a direct property of a material. It relies both on the geometry of the body and on the elasticy of the material.
In physics, the laws that describe the deflection of a wave as it makes its transition from one material into another. The measure of change in angle is a constant, a property of the material itself.
Tieing things together proves to be a toughy. Th
Was that my cue?
Thomas Jouanjean
« Reply #8 on: March 28, 2009, 06:54:12 am »
Z is impedance. 'm' is mass of the partition in dAN (or ~kg) per m
Thomas Jouanjean
Pro Audio Partners:
ATC Loudspeakers
J.F.Oros
« Reply #9 on: March 28, 2009, 08:32:16 am »
That graph would have been even more interesting if we could zoom on the 0-500Hz range (where the fun usually is  Very Happy ).
[ Flaviu Oros - acoustics engineer ]
[ JF Studio Design - Romania ]
Thomas Jouanjean
« Reply #10 on: March 28, 2009, 12:28:45 pm »
J.F.Oros wrote on Sat, 28 March 2009 07:32
I know.
We live in a crual world.
(If you look carefully you can see "it" though. The beast.  Twisted Evil )
Thomas Jouanjean
Pro Audio Partners:
ATC Loudspeakers
Sigert
« Reply #11 on: March 30, 2009, 11:41:20 am »
I can't find any info on those formula you posted earlier, Tomas. And nobody I talk to seems to know anything usefull about them either. Maybe I just hang out with the wrong people. Laughing
Re-reading the first formula, it occured to me that (assuming a broadband source) the only variable is mass. So that must be what people refer to as the 'mass law', right? Doubling the mass means doubling the isolation of a boundary. That seems reasonable for a single leaf wall, from what I read, up to its primary resonance frequency.
Second question: in those formulas, what does 'D' stand for?
Was that my cue?
Thomas Jouanjean
« Reply #12 on: March 30, 2009, 01:56:52 pm »
'D' is rigidity of the partition. It's calculated like that:
D= (Eh
Thomas Jouanjean
Pro Audio Partners:
ATC Loudspeakers
Sigert
« Reply #13 on: March 31, 2009, 09:07:47 am »
I took both the "mass law" and "Rigidity" formula given earlier in this thread and whipped up an Excell graph. Pretty huge numbers there, but not at all sure what they mean. I can't believe these are in themselves isolation values. That'd be crazy. Surprised
Data used in calculations is what info I gathered about a 2layer sheetrock wall.
h=0.025 m
E=2,3*10^9 N/m
Was that my cue?
andrebrito
« Reply #14 on: April 01, 2009, 04:32:31 pm »
Place the x axis in log please ! Much better way to check that chart
