R/E/P > Brad Blackwood
For those with passive monitor attenuators..
<< < (2/11) > >>
dcollins:
Viitalahde wrote on Sat, 07 March 2009 06:04
What are you using?
Shallco 2k5 bridged T.
Quote:
Since this is going get into general console discussion anyway, let me ask one more thing:
How many of you are using something more extended as a "console" than a monitor volume controller?
3 monitor inputs and 3 insert points.  Of which I use one of each on a normal basis.
DC
bblackwood:
dcollins wrote on Sat, 07 March 2009 15:32
What are you using?
Ditto (go figure).
Six sources, seven monitor positions, six inserts.
Andrew Hamilton:
2.5k? Oh, DC...  My 5k system craps out at 227 kHz. );
(Or, do I add the amp's input Z to that of the attenuator?  If so, I'm actually down at 42 kHz before I enter the cross overs)
You know, 1/2πRC...    My feeling is that I would not add the amp's 22k Ohm input Z to the 5k Ohms of the attenuator, because the resistive part of the amp's impedance is _after_ the capacitative part of the network (i.e., there's no more cable once it hits the amp).    However, I have read people to write that one must factor in all the Z's in each circuit...
Andrew
Viitalahde:
Been thinking about this.
2k5 or 5k bridged-T sounds like a good route. I just bought some naked Shallcos off eBay, but we'll see if I get around designing my own attenuator or ordering one from Marchand.
I was looking at Dangerous Master earlier, and the three insert points got me curious. Makes sense to me. I could group pieces that usually go together behind one insert, and still use each piece's own bypass. Not all of my tools have a bypass (since it's in the console), but some do.
It's easy to go nuts with console design, when all I need is a simple one. The current one has pre-process attenuators, which I never use. The first one had a fancy L mono/mono/R mono switch, which could be handy but not really necessary.
Restrictions have always made me tick better.
jdg:
i am on rev 5 of mine. and i really simplified it.
6 source, 1 insert, 3 outputs. 5k attenuator
the one insert is now really just a global bypass for the whole process chain
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
