Pages: 1 [2] 3  All   Go Down
Author Topic: small room office floor soundproofing feedback  (Read 13733 times)
Lincoln McCulloch
Re: small room office floor soundproofing feedback
« Reply #15 on: June 29, 2010, 10:27:20 AM »
ok, pics it shall be then Smile
but just some of the highlights...
A shot of what it looked like when we leased it.  Just a basic 3rd floor office.
index.php/fa/15011/0/
Lincoln McCulloch
« Reply #16 on: June 29, 2010, 10:28:33 AM »
The first of many van loads of materials.
index.php/fa/15012/0/
Lincoln McCulloch
« Reply #17 on: June 29, 2010, 10:30:55 AM »
A shot of the decoupled floor.
Heavy poly down on the carpet and up the walls about 8 inches.
Kinetics isolation pads every 12" or so, this is the only thing touching the existing room.  We're about 1" away from all the walls as well.
2x4 framing, about 12" boxes.
index.php/fa/15013/0/
Lincoln McCulloch
« Reply #18 on: June 29, 2010, 10:32:32 AM »
Next stages of the floor.
Cavities filled with insulation.
Acoustic caulking then 1/2" plywood.
index.php/fa/15014/0/
Lincoln McCulloch
« Reply #19 on: June 29, 2010, 10:34:15 AM »
Next stage of the floor.
Foam roll.  The stuff used under hardwood floors to help deaden the sound.
Then another layer of 1/2" plywood overlapping all seams of the first layer.
On top of that went some heavy rubber backed carpet tiles I found used for $100 (stroke of luck for sure).
index.php/fa/15015/0/
Lincoln McCulloch
« Reply #20 on: June 29, 2010, 10:35:33 AM »
A shot of some conduit we ran to be able to get cables around the door without making a mess on the floor.
You can also see the framing around the door that went up.  This was to hang a heavy oversized inner door (see other pics).
index.php/fa/15016/0/
Lincoln McCulloch
« Reply #21 on: June 29, 2010, 10:37:26 AM »
The entire edge around the floor was filled with insulation, then a thick bead of acoustic caulking.
index.php/fa/15017/0/
Lincoln McCulloch
« Reply #22 on: June 29, 2010, 10:39:09 AM »
The drum room separation wall.  It was only secured to the floating floor.  The rest of the wall doesn't touch the room apart from some acoustic caulking down the sides (next pic).
index.php/fa/15022/0/
Lincoln McCulloch
« Reply #23 on: June 29, 2010, 08:54:09 PM »
Showing one edge of the drum room wall.  The wall floats between 2x4's that are attached to the room wall.  The gap is filled with acoustic caulking only, no other physical connection.
index.php/fa/15023/0/
Lincoln McCulloch
« Reply #24 on: June 29, 2010, 08:56:43 PM »
The drum room wall, insulated and drywalled both sides.  Solid core door for access.  Double pane thermo windows to be able to see the drummer.  The room was built for 2 drum kits, one behind each window.
There is a drum room sub-mixer for dialing in your own playback mix (I took a split off all mics and sent that to the drum room mixer) as well as submixing the drum mics back to the main board in the main room for others to hear the drums as they wish.
When recording, I run mics directly from the drums to the main board bypassing the drum room mixer.
index.php/fa/15024/0/
Lincoln McCulloch
« Reply #25 on: June 29, 2010, 08:58:15 PM »
One of the 2 oversized door sandwiches that were hung on floating door boxes built around the pre-existing door.
It is a 2x4 frame with 1/2" plywood, then Green Glue to a 1/2" drywall, then insulation and more plywood.  Every contact surface gets acoustic caulking.
index.php/fa/15025/0/
Lincoln McCulloch
« Reply #26 on: June 29, 2010, 08:59:26 PM »
The drywall on top of the Green Glue'd plywood.
index.php/fa/15026/0/
Lincoln McCulloch
« Reply #27 on: June 29, 2010, 09:00:36 PM »
Insulation on top of the drywall.
index.php/fa/15027/0/
Lincoln McCulloch
« Reply #28 on: June 29, 2010, 09:01:52 PM »
The other layer of plywood making a finished door.  It is VERY heavy and was put up with 4 heavy duty hinges, plus a caster on the outer edge that rolls along the floor.
index.php/fa/15028/0/
Lincoln McCulloch
« Reply #29 on: June 29, 2010, 09:03:09 PM »
View into the drum room with drums in it (and the sub-mixer).
index.php/fa/15029/0/
Pages: 1 [2] 3  All   Go Up
Page created in 0.074 seconds with 20 queries.
